Mach 7's ?!?!
Old Jan 8, 2005 | 11:30 PM
faster_than_ford's Avatar
Mach 7's ?!?!
I was just looking on Don's website and saw the Mach 7 injectors. And I was wondering, consider you had a completley stock 02 3500 H.O. what supporting mods would you have to do to be able to run those 7's? I don't plan on using them, but for reference I would really like a complete list of supporting mods if anyone knows.
Old Jan 9, 2005 | 01:12 AM
joefarmer's Avatar
You'd need larger twins for enough air (n2o would help too), a healthy IP, a way to keep the fuel pressure supplied for the IP, headwork - orings or firerings (or just studs like Tim ), a transmission to hold the power, a nice fueling box or 2 and an good plastic surgeon to remove the permanent grin.
brandon.
Old Jan 9, 2005 | 09:20 AM
Timinva's Avatar
DTR Advertiser
If you wanted to run them on a ETH you would need a hotrod vp44 as well. No way a 028 HO pump can move enough fuel for 7s. Tim
Old Jan 9, 2005 | 12:33 PM
BigBlue's Avatar
I wonder how much smoke a Mach 7 puts out.
Old Jan 9, 2005 | 12:40 PM
Kyle Graham's Avatar
Probably simular to a freight train pulling a grade
Old Jan 9, 2005 | 01:15 PM
BigBlue's Avatar
Old Jan 9, 2005 | 02:26 PM
Timinva's Avatar
DTR Advertiser
Driving everyday The 7s smoke about the same as 6s. When I turned up the comp up though it smoked hard. Everyday driving smoke is controlable with twins, just hope your injection pump is up to the 7s. Tim
Old Jan 9, 2005 | 02:46 PM
Don M's Avatar
DTR Advertiser
Not just the pump, but the supporting system wrapped around them or you will just drop off in power over a Mach 6. You need a cam, a ported head and a fresh pump with little to no cam ring wear that will still deliver the fuel these things need. Of course if you have some nitrous...those requirements go away.
They will run on a properly designed single charger, but you cant drive them around and not expect some smoke.
Don~
Old Jan 9, 2005 | 03:02 PM
BigBlue's Avatar
So your saying that if you've got 150k miles on the original injection pump that it's probably not gonna support these injectors. What kind of power have you seen out of these injectors? EGT's?
Old Jan 11, 2005 | 12:43 PM
HOHN's Avatar
It's fun to dream, isn't it?
Personally, Mach 3.5s are my injector limit.
Justin
Old Jan 11, 2005 | 02:51 PM
signature600's Avatar
Sounds like these bad boys need a P-pump to throw fuel at them
Overvalved, computerized, @#%&$#
HeHe
Chris
Old Jan 11, 2005 | 05:06 PM
joefarmer's Avatar
Hey! I resemble that statement!
brandon.
Old Jan 11, 2005 | 05:10 PM
You're overvalved? You're WAAAAY too computerized, and definately @#%&$#
OOHHHH, you meant the truck
Chris
RonA
14
Sep 4, 2007 11:09 AM
sway825
Dec 8, 2004 10:21 PM
smittybuilt
14
Jan 5, 2004 01:42 PM
jimjawz
Dec 30, 2003 12:14 AM
BAD HABIT
Oct 25, 2003 11:52 PM
