Don M. MACH II INJECTORS NEED DIRECTIONS
Received my MACH II's yesterday. ;D Need some tips on install. Can't hardly wait to feel the power. I want the install to go quick & easy. Have to have my friend do the back three because I connot climb on the truck. So details will surely help.
Re:Don M. MACH II INJECTORS NEED DIRECTIONS
Easy as pie make sure you have a 3/4" stubby and you will thank me over and over for that tip! Easily done.
Remove valve cover
Remove keepers on injectors
Use valve cover bolt into the top of the injector as a puller
Loosten the golden nut on the block and pull the line back
Slightly pry out on the tube in the block the gold line went to and pull up on the injector do all 6
Reprime and ;D
Remove valve cover
Reprime and ;D
RonA
14
Sep 4, 2007 11:09 AM
cat1713
Sep 19, 2006 04:34 AM
sway825
Dec 8, 2004 10:21 PM
