Mach 3 ...
Old Jan 12, 2009 | 03:28 PM
12valve's Avatar
Mach 3 ...
So got in the Mach 3, I was previously running jammer 3
I basicly wanted this injector to have smooth idle and cleaner power. If It'd net me power, would be a bonus!
Now i get tons more smoke, normal driving - low boost, and at WOT it smokes more too, EGTs get hotter too!
Does that sound correct?
Old Jan 12, 2009 | 03:57 PM
Fishin2Deep4U's Avatar
Honestly, it's probably adding more fuel than the old Jammers. There are many folks out there selling "Jammer" nozzles and there is a huge variation in flow rates among these manufacturers.
Dave
Old Jan 13, 2009 | 01:29 PM
12valve's Avatar
obviously its adding more fuel, specially daily driving around it always makes a smoke trail now, which before was easier to control! (even with Fuel box off)
Old Jan 13, 2009 | 03:04 PM
mcoleman's Avatar
That's kind of odd as I drive with Mach 4s daily with no smoke unless I want it. And I have a 66 mm charger on top of that.
Old Jan 13, 2009 | 03:48 PM
Flatbed24v's Avatar
have you checked for a boost leak?
Old Jan 15, 2009 | 03:22 PM
12valve's Avatar
its making the same boost it always has about 42 psi max.
BTW do mach injectors have a different tip then the stock injectors?, because these have a different tip then the jammers and the stock inj.
click for Picture
stock nozzle on the left
Old Jan 15, 2009 | 06:17 PM
Don M's Avatar
DTR Advertiser
Where did you get those? Those might be the oldest version we made back in 2002. The new injector is way cleaner and way less heat than those old things.
Old Jan 16, 2009 | 04:12 PM
12valve's Avatar
They used to be in Mecham Evans' drag truck, owner of Cedar City diesel.
Injectors have a date of 7/03 engraved
Don, what kind of money would you need to rebuild these with the new version?
RonA
14
Sep 4, 2007 11:09 AM
sway825
Dec 8, 2004 10:21 PM
smittybuilt
14
Jan 5, 2004 01:42 PM
jimjawz
Dec 30, 2003 12:14 AM
BAD HABIT
Oct 25, 2003 11:52 PM
