LP dying ?? FASS and RASP ??
Originally posted by Raw power
My feelings are that you need to do more than just replace your pump. FASS, Airdog, and Rasp, are all capable of moving more fuel that the stock tank module is capable of delivering. Problems can occur. I have the FASS and a custom built tank module. Picture is of unfinished unit as I am still waiting for sender and was not finished plumbing in this pic. Also keep in mind that the stock module is a bucket in which hot return fuel is ddumped. This is a no no in the diesel world. Why would DC do this. Compare the DC module to any other Diesel setup you have ever seen. I am convinced this is the main source of our trouble.
Off Soapbox for now.
Custom module uses Capacitance type probe to measure fuel level (no moving parts)
Happened again today in the drive thru. I am starting to lean toward this being an ECM or PCM probkem, because pump is fine 99% of the time, only happens when shutting motor off, and restarting within 2 mins, and then it only happens 10% of the time.
65pacecar
31
Sep 12, 2007 11:05 PM
KBF
May 9, 2005 10:54 AM
rmrc
Feb 13, 2005 05:25 PM
