Low Power
Old Sep 7, 2007 | 07:56 PM
mstordahl's Avatar
Low Power
Hey guys, just a question for you. Have a friend with a 2001 3500 HO 6spd 4.10 rear and dynoed 370hp and 980tq with a afe cold air intake, BD super B turbo, 3 piece manifold, 4" turbo back exhaust, 130hp injectors, BD pusher pump kit, edge juice with attitude. Seems low on the numbers? The truck will pull harder on every level from stock to 3, then no difference on 4 or 5. Any ideas on why they would be low like this? Also on WOT run, cannot get egt over 1050.
TIA
Old Sep 7, 2007 | 08:01 PM
BBA's Avatar
BBA
Bad injection pump maybe.
Why complain about low egt's?
Old Sep 8, 2007 | 10:02 AM
mstordahl's Avatar
Not complaining about low egts, just that the truck seems to be putting down alot less power than others with the same thing. Just curious to see if anybody had any ideas about it.
Old Sep 8, 2007 | 10:25 AM
Ph4tty's Avatar
Recheck the tap on the IP.
Old Sep 8, 2007 | 01:00 PM
Big Blue24's Avatar
Where is the pyro mounted? Those numbers seem low even for just injectors and no comp.
Old Sep 9, 2007 | 04:31 PM
mstordahl's Avatar
The pyro is right in the manifold in front of the turbo, so it should be accurate. I will get him to check the tap on the pump as well. Also, when we installed all of the mods and the juice and hooked up the fuel psi sensor, he was only at 4 psi at idle, and soon as you touched the throttle it dropped right to 0. Who knows how long it had been running like that. Could that also have damaged the pump enough that it could not put out the fuel it should?
junkdog
Jan 13, 2009 10:55 AM
Keyser
Apr 20, 2008 06:24 PM
city slicker
Oct 24, 2007 10:23 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
spitzair
Jan 24, 2006 03:42 PM
