Lift pump replacment. What are my options?
From what I've heard in my other thread, the lift pump may be in need of replacement on my 98. I've got 5 PSI at WOT and that is boarderline from what I understand. If I don't want to replace it with an OEM or equivalent unit, what are my aftermarket options and what do I need to spend? I don't care to spend a little extra if I need to in order to eliminate a potential future problem.
Are most of these lift pump replacements a bolt on item? Is the factory lift pump electric or mechanical?
Thanks.
Conn
Thanks.
Conn
If you want to ditch the stock lift pump check out the FASS and FASS II systems. Many around here are very happy with them.
http://www.piersdiesel.com/FASS.htm
Love my FASS! More info here...on Mfg website -
http://www.dieselpp.com/
FASS I - $500-550 range
FASS II - $350 - 400 Uses CTD fuel filter and no air/water separator unit
RJ
RJ
if that's too pricey there are other options
$240 total for the new LP and Vulcan relocation kit (with larger fuel line and no banjo bolts). I never see below 12 psi. The kit is complete and easy to install.
The chrysler conversion to an in-tank pump is another good option. Part number 5175538AA. Should run you about the same as what another lift pump would run and take about the same time to install. Kit come complete with everything needed to make the conversion. Any dealer can get this for you.
TRAVIST
TRAVIST
crap. i was wanting to pick up a Comp Drag box soon, but I guess I need to address the fuel problem first. I'm sure adding the box would suck the PSI down to almost nothing.
i picked up an issue of four wheeler magazine the other night and they had an ad in their 24 valve uildup article about a BD lift pump kit. any good word on the BD stuff? seems like it retailed at around $265?
wood_n_soldier
21
Dec 21, 2005 11:01 PM
