Leaking fuel return line/fitting
Old May 21, 2012 | 07:17 PM
JARHEAD's Avatar
Just got done with the first test drive. fuel dripping from tank. got up in there and pretty sure it is the return line leaking. installed a DSV, doubt that is what is leaking. Are those factory lines easy to start to leak after removing? i cant just pull it off so i know it "clicked"...any ideas?
Old May 21, 2012 | 10:44 PM
JARHEAD's Avatar
If it is my return Line fitting that is leaking, is there anything wrong with cutting the line and using rubber hose to go from there to top of tank and secure with a hose clamp??? Eliminates that stupid fitting.
Old May 21, 2012 | 10:55 PM
BigIron70's Avatar
Cummins Guru
That would work but they also sell a kit to repair. Stealerships stock them but more money
Most likely the o-ring got damaged
http://www.summitracing.com/search/D...e-Repair-Kits/
Old May 21, 2012 | 11:15 PM
JARHEAD's Avatar
Is the factory fuel line 3/8"? The steel lines?
Old May 21, 2012 | 11:57 PM
BigIron70's Avatar
Cummins Guru
Return is 5/16, supply is 3/8. Remove and check if oring is still there. Make sure plastic nipple didn't crack. You will need to remove suppy to get in to remove return
Old May 23, 2012 | 11:50 AM
infidel's Avatar
That's the way I do it but while I'm at it I abandon all the failure prone stock lines and run quality diesel hose all the way from tank to engine.
Excellent price on excellent hose> http://www.mmimarine.com/mmi/index.p...=list&start=60
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
mr T
Sep 1, 2006 05:41 PM
blueberry
Feb 1, 2006 09:48 AM
banks twinram
Feb 13, 2005 04:09 PM
