Laser Cut Delivery Valves???
Old Jan 31, 2007 | 01:19 AM
torqmonster's Avatar
I have a 1998 12 valve, 5 speed. I have a #10 TST plate slide forward, AFC spring kit, 3000 GSK, 60lb valve springs, BHAF, 4" downpipe to 5" stacks, and a PDR HX-40 turbo. My question is, I am thinking about getting laser cut delivery valves, and wondering how much it will give me, or would I be better off getting injectors first? Or doesn't it matter? Thanks!
Old Jan 31, 2007 | 01:23 AM
Forrest Nearing's Avatar
get a clutch and a set of injectors
Old Jan 31, 2007 | 01:28 AM
I have a valair clutch
Old Jan 31, 2007 | 07:38 AM
signature600's Avatar
You will be out of air with either...but I think injectors would be a better next BOMB! The Laser Cuts move a TON of fuel, and can get awful smokey and hot if you don't have a lot of air...which I don't think you do with an HX40!
Chris
Old Jan 31, 2007 | 10:01 AM
I'd do injectors, put some 4k springs in your governor kit, and put some water/meth on it.
Old Jan 31, 2007 | 10:05 AM
Sounds like good advice
Chris
Old Jan 31, 2007 | 07:29 PM
65fury's Avatar
sounds like my truck may run a little smokey , i have laser cut dvs anda #4 fuel plate, with a stock turbo, well until i get the 60mm compressor upgrade that is. but i have a valet switch so i can cut the fuel if things get to hot.
jason
Old Feb 1, 2007 | 07:30 AM
YOu're gonna need more charger...that 60mm is just a warmup!
Chris
Old Feb 1, 2007 | 07:58 AM
65fury's Avatar
Chris
yah i knew that, thats why im going to build twins after i get a couple hundred break in miles on the motor and trans, then i'll add injectors and see what that cummins can do
jason
Old Feb 1, 2007 | 08:27 AM
Now that's a good plan
Chris
stock600
14
Feb 25, 2008 11:21 AM
rebel5422
Jan 25, 2008 08:30 PM
Diesel Dave2
Sep 17, 2007 08:35 PM
Rampuller
Sep 7, 2003 08:19 PM
Cummnzpowr
Jul 21, 2003 07:41 PM
