largest sticks you have run p-pump or vp?
I have a set of 6 x .017's in my truck right now. I have a p-pumped 24v motor. They run and idle perfectly but they haze at idle(alot when cold) and there is a constant stream of smoke going down the road. Even with my afc setup with double springs and no full fuel till 55 psi. They actually clean up well on top though. I'm running 64/71/16 over S480 twins at the moment.
I have J&L EDM 6x15 and went 11.85 in a 1/4 113 mph and cleand up the smoke I put my 200 s in for winter looking for a good stick to try for next time I hit the track my vp is stock just trying to see when it will run out of fule my fass has 17 lbs at the end of a pass thanks of all help
ocsurf16
Nov 26, 2006 08:40 PM
squirlchasr919
Oct 29, 2006 05:04 PM
ramlovingvet
Nov 18, 2002 09:55 AM
