K&N Drop in Claening Intervals
Old Apr 10, 2008 | 09:33 AM
supr's Avatar
For those of you using K&N, what do you find is the optimal mieleage for cleaning? I have read 50-100k. Cleaning too often causes problems(oil down stream).
Your thoughts?
Old Apr 10, 2008 | 10:12 AM
carl48's Avatar
if you like your truck get rid of the K&N it will ruin the motor fast we have pix of the damage to the truck of ours that we tried them on cummin's has a warning out on them and if you will do a search a lot of other pix are posted of damage you can take a new one out of the box hold it up to the light and see what the problem is
Old Apr 10, 2008 | 10:16 AM
infidel's Avatar
A dirty filter filters better as long as it doesn't become so dirty as to become restrictive.
I trust my filter minder, which has never dropped with a K&N and service every 100k. No peaking inside the airbox inbetween, it is counterproductive and likely to cause a bad seal.
At every oil change I remove the intake tube from the turbo to allow easier access to the oil filter. White rag wipe inside the tube has aways come up clean. Oil analysis has always had low silicon numbers which indicates the filter is doing it's job contrary to what many K&N haters imply. Most problems stem from over servicing, over oiling or not following the directions.
I bought my K&N from Cummins Northwest which recommended them at the time.
Seems to me that K&N would be out of business if their products truly ruined engines.
Old Apr 10, 2008 | 08:10 PM
Rampage1967's Avatar
I clean mine when performance drops off, as recomended by K & N.
Old Apr 10, 2008 | 08:17 PM
pronstar's Avatar
Your butt dyno must be better than mine...
Old Apr 11, 2008 | 05:48 AM
12 flapper's Avatar
I like my K&N I use them on everything, the biggest from I hear is improper use. I check mine everynow and then but I don;t clean it that much. I usaully go by my butt dyno. or if it looks really nasty with dirt build up.
Old Apr 11, 2008 | 08:41 AM
I just watch boost gauge & such . .when boost drops & EGT rise i clean it.
BTW. . intake stays clean too.
Old Apr 11, 2008 | 04:17 PM
BPoulsen's Avatar
I haven't had to clean mine in 30k miles yet - it looks a little dirty, but not bad at all. I check the tube to the turbo and it's clean...
Old Apr 11, 2008 | 09:34 PM
surfram's Avatar
Are you running the large K&N conical (part# E-0776) drop-in? Have you had an oil analysis done?
Old Apr 12, 2008 | 09:33 AM
carl48's Avatar
if you do an oil analysis you can also see the damage being done by the K&N
Old Apr 12, 2008 | 12:50 PM
bullboy85's Avatar
well from what iv seen, read and heard k&n's are great for serten conditions, and horible for others, but i fined that its true of any oiled filter, if your in a relitivaly dusty area then steer clear of any oiled filter, if not then put in what you want it doesnt make that big of difference
Old Apr 12, 2008 | 05:47 PM
CoastalDav's Avatar
My K&N has about 160,000 on it, maybe less or more. I clean it every 10,000 miles when I change the fuel filter. My filter minder has never moved either with the K&N installed.
Dave
Old Apr 12, 2008 | 07:09 PM
Clayten's Avatar
DTR's Toad Wrangler
If you are in real dusty conditions you can put on a wrap (for conical filters). Uni makes one so does K&N. I have a nylon type of wrap but I am thinking of putting on the Uni filter wrap.
Ron R
Sep 16, 2008 11:09 AM
samahi72
Jul 26, 2006 11:55 AM
BADodge2003
13
Jul 24, 2003 03:21 PM
Monty
Jun 16, 2003 12:14 PM
kevinn
Apr 6, 2003 09:18 PM
