K&N for BHAF
K&N for BHAF
I was browsing through the local Autozone today and ran across a K&N filter that can be used as a BHAF. Not sure what it was really designed for but works excellent for this setup. Install is the same as normal. Part # is E-1796 and was $39.99. Thought you all would like to know. Thinking of trying to route it into the wheel well to get away from engine heat. I have done this for Mustangs in the past and on the dyno it would usually get another 5-7 HP over just a K&N cone filter in the engine compartment. If I succeed I will post the results. Man that turbo REALLY sings now!!!
Guest
Posts: n/a
Re:K&N for BHAF
Two problems with this filter (I tried one a while back):
(1) The outlet for the K&N #1796 is 3 inches, rather than the 4 inches on the turbo hose. I had to fab an 3"-to-4" adapter out of PVC pipe. But I lost potential air flow.
(2) The surface area of the #1796 is about two-thirds that of the BHAF and about three-quarters that of the AFE. So more potential air flow is lost there. ]
To my mind, that sort of air flow loss nearly cancels out any air flow advantage you'd get from the K&N's construction.
Given those two reasons, along with the Cummins recommendation against K&N filters, and the K&N's questionable ability to filter fine dust -- my own experience, plus tests I've read about -- I decided to go with another solution.
It does give a nice sound to the turbo, though.
GP
GP
Re:K&N for BHAF
I didn't know anything about Cummins recommending against K&N usage. I have always had good luck with their filters. Anyway I already have it and it will have to stay until I get the Scotty II. ;D Fabbing up the 4" to 3" reducer is a piece of cake. As far as any air flow restrictions, it is ALOT better than the factory airbox. Also on the filtration issues, I believe I saw an independant study done and the filter filters down to 1 micron. That is better than your oil filter does. Others may be better, but for $40 I don't think you can go wrong. Just my .02
Guest
Posts: n/a
Re:K&N for BHAF
I agree. It's probably a better solution than the factory box, as long as you don't get into the dirt. I do -- and that's largely why the 1796 is currently on my shelf. There's a lot of controversy over the K&N's ability to filter "fines". Until that's put to rest, I'd rather be safe.
Glad you brought this up, though.
GP
GP
Re:K&N for BHAF
Try a K&N RE0880. It has the correct neck on it and works fine. Lots of the guys on the other board changed to the BHAF because they did not like oiled filters and the high suction on them seemed to be pulling oil from the filter and depositing it on the turbo blades.<br><br>I have an RE0880 sitting on top of my freezer for this very reason.... <br><br><br>JR2
Re:K&N for BHAF
Rev, BHAF=Big Honkin' Air Filter. It's basically a big round filter from a big rig which replaces the stock air box. You pull the box and lay the bare filter in it's former location. The turbo hose will fit clamp onto the end of the filter. AFE is a brand name. YOu can get a look at one here. http://store.dieseltruckresource.com/dodge-diesel/
Pull the silencer ring from the turbo and hook a BHAF on the end it, and you've got a screamin' intake.
Re:K&N for BHAF
[quote author=CMN_NOT_STROKN link=board=7;threadid=5630;start=0#49462 date=1034009256]<br>I didn't know anything about Cummins recommending against K&N usage. <br>[/quote]<br><br>I ran a K&N in the stock box for a while before I heard it too. I called Cummins and talked to one of their techs and it's not just K&N. They don't recommend using ANY oiled filter. But after spending some time talking with the gentlemen and asking him WHY I came to the conclusion that it was time for me to buy my AFE Megacanon ;D they couldn't give me any reason other than what K&N and AFE give. Each company warns against using in extremely dusty conditions and that's the same thing the Cummins rep said.<br><br>[quote author=CMN_NOT_STROKN link=board=7;threadid=5630;start=0#49462 date=1034009256]<br>Also on the filtration issues, I believe I saw an independant study done and the filter filters down to 1 micron. That is better than your oil filter does. Others may be better, but for $40 I don't think you can go wrong. Just my .02<br>[/quote]<br><br>K&N is an oiled filter
Mark Hodowanec
Feb 26, 2006 08:35 PM
