just bought some ebay projector lights and need hid info
i finally got so ****** off with my horrible lighting stock headlights that i bought some halo projector lights.
has anyone used an hid kit in the highbeam location yet? i need to see moose and or deer. our nearest town is 4 hours south so i do a lot of driving with no one around. (good ol alaska highway)
and this way if i run it in the high beam location and someone is coming i can turn the high beams off (hids) and i won't be blinding them.
also does anyone know if these ebay lights come with the bulbs for the projectors? i honestly have no idea.
thanks
thanks
If the projector wasn't designed for HID, it won't respond well to HID. Hence, illegal. TYC made some projectors that responded ok to HIDs, they are DOT legal projectors for halogens. HID's run cooler than halogen bulbs and draw only 35 watts instead of 55.
I'm in the process of finishing up my HID retro. Can't wait. Hopefully this weekend but maybe next. I'll be running OEM BMW projectors with HIDs in the sport headlights so I'll have an extra 9004 halogen bulb in each headlight as well. It's going to be some INSANE light...
halogen uses more power for less output and less temp. compaired to the HID's that use less power for more output with a higher temperature.....
which size bulb goes into the projector section? i know its 9004 for the high beam (the non projector hole). my hid's should show up this week. i'm not worried about heat.. out weather doesn't get warm enough for anything to melt.
i'll take some before and after pics for the truth i guess.
most projectors i've seen use an H-1 in both high beam and the projector.... there is an adapter harness where it plugs into your existing wiring.... please post up before and after pics so we can see how they hold up to the heat that builds up in the enclosed assembly....
pipeman90
Mar 29, 2011 09:23 AM
IPDiesel
Jan 19, 2011 02:58 AM
chopper9451
Dec 30, 2008 12:41 AM
storx
Jan 7, 2006 07:13 AM
