Isspro Pyro Thermocouple Questions
Old May 15, 2011 | 11:47 AM
scjfly's Avatar
Hey Guys,
I ordered some gauges last week and they finally showed up. Only thing is, the Pyro Thermocouple seems to have the wrong sized fitting.
The thermocouple that was sent is a R658SHT-8F. The box says it is a Adjustable Short Hi-Temp with 1/8" Fitting. The thermocouple has the same part # on it.
The problem is the fitting seems to be much bigger than 1/8". Looks more like it matches up with my 1/2 inch dies. Could this be 1/4 NPT? Would it be dumb to use this fitting or should I send back to get the 1/8"? Would I need a smaller probe or are they universal?
Thanks for you insight.
Clark
Old May 15, 2011 | 12:23 PM
Doj Dewd's Avatar
first of all, i would verify with a 1/8 NPT tap or die before sending anything back.
i would use 1/8 if it doesn't throw a wrench into your plans too much.
only reason for my thoughts on this is that he 1/8 NPT seems to be standard across the board for fittings such as these from various gauge and performance product manufacturers should you ever decide to change down the road. that being said - you could use what you have, then just get a reducer bushing at a later date if needed . . .
Old May 15, 2011 | 03:09 PM
KATOOM's Avatar
The smaller the hole you will have to drill in the exhaust manifold, the better. And as already mentioned, make sure you know what size it actually is before you hastily send anything back. 1/8" would be around a 3/8" hole and a 1/4" would be more like a 1/2" hole.....or so. Also, when you drill and tap the hole, dont run the tap to far in the manifold otherwise you'll have to tighten the compression fitting so much that it will run into the manifold to far and become an obstruction.
Old May 15, 2011 | 03:25 PM
scjfly's Avatar
Thanks guys, I'll be patient and wait till I get the correct fitting.
It's definitely 1/4" npt cause its roughly 1/2" diameter. I also cross checked it with my 1/8" npt tap that I used for my fuel pressure gauge and its way bigger.
All i can figure is they accidentally sent a fitting for the post turbo bung.
Thanks,
Clark
Old May 15, 2011 | 05:19 PM
Doj Dewd's Avatar
good point on the smaller hole = less chance of cracking . . .
Old May 15, 2011 | 05:52 PM
wlowe's Avatar
When I originally installed my Isspro thermocouple years ago it was a 1/4 npt. A few years later I installed the Edge Attitude thermocouple which was 1/8 NPT. I just installed a bushing in the original hole to neck it down to 1/8 NPT.
Old May 16, 2011 | 11:04 AM
scjfly's Avatar
Called Isspro this morning and they confirmed that I accidentily got a 1/4" NPT fitting. They are shipping me the correct hi temp steel fitting today. Great guy and great service.
He said the majority they sell now days ship with the 1/4" fitting.
Thanks for all your input
Clark
Old May 17, 2011 | 04:07 PM
scjfly's Avatar
No sweat Michael, I was very impressed with the customer service I received! Looking forward to the 1/8" fitting arriving in the mail.
Thanks again,
Clark
Old May 18, 2011 | 08:02 AM
RowJ's Avatar
Ditto! No biggie. And I know no one that has had cracks from the 1/4 NPT.
RJ
Old May 19, 2011 | 12:53 AM
scjfly's Avatar
Received the 1/8" fitting today in the mail (called Isspro on Monday, arrived on Wednesday) and got my pyro all up and running!
Very impressed with Isspro.
Thanks,
Clark
Lil Dog
May 30, 2013 03:42 PM
jogl
Jan 12, 2007 09:46 PM
skynyrd
Oct 20, 2006 11:09 AM
PeytonMaterne
Jan 3, 2006 03:08 AM
LarryJ
14
Dec 8, 2003 12:30 AM
