isspro fuel pressure gauge
Old Dec 30, 2007 | 10:08 PM
bpollard1248's Avatar
im looking at buying the kit from vulcan for isspro fp gauge and wanted to know if i would need anything else to hook it up. where does it hook up on a 2001 24v?? thanx guys
Old Dec 30, 2007 | 10:18 PM
sleeper01's Avatar
i put my sensor on the pump where the inlet is to the left is a plug that takes a star driver to remove i just put the elec. sensor in there i was more interested in knowing what the psi is at the pump and not at the water fuel seperator
Old Dec 31, 2007 | 09:28 AM
MSquare's Avatar
Contact Eric/Vulcan, he will hook you up with everything you need! Eric makes/has every fitting known to man. Look into his braided SS lines too! The kit you order from him will come with everything you need (including a sweet isolator).
Old Dec 31, 2007 | 01:57 PM
afoulk's Avatar
if you decide to go without a isolator and run fuel straight to the gauge, make sure you get a snubber (needle) valve to help dampen the pulsations in the fuel. If not, it'll ruin your gauge. And if something should happen that your fp line leaks, you can use the snubber valve to shut the fuel off to the gauge. The isspro gauges are a mechanical gauge, so they don't use a electronic sending unit.
Random Acts
Dec 16, 2007 02:04 AM
65pacecar
Oct 1, 2007 09:18 PM
quadstar
Sep 27, 2007 09:52 AM
66fordcrewcab
Mar 21, 2007 01:47 PM
deezulsmoke
0
Mar 21, 2005 09:59 PM
