isspro fuel pressure gauge
Old Sep 25, 2007 | 05:51 PM
quadstar's Avatar
I thought i read somewhere on here that when installing fuel pressure gauges, it was not nessecary to install the isolator? is there any truth to this. I just bought the nice set of isspros and I am planning on hooking them up one of these nights, and I just wanted to get the scoop. any other things I should be aware of? i read thru the instructions once, and I'm very mechanically skilled, just was hoping to get some helpfull hints from some of the "old pros" on the site
Old Sep 25, 2007 | 06:27 PM
trx's Avatar
trx
installed isspro fuel guage as well as isolator in my truck just for the simple reason if it did leak didn't want diesel in my cab if you already have it might as well put it in install was easy
Old Sep 25, 2007 | 06:37 PM
tritont's Avatar
many like myself also use anti-freeze from the isolator into the truck to the gauge as an extra precaution to avoid diesel in the cab. Plus, it's not as dangerous.
To answer your question.... unless you mount the gauge outside the truck... you really should use a isolator.
Old Sep 27, 2007 | 01:27 AM
MrMoparMan's Avatar
What did you use for tubing to and from the isolator. I am having trouble getting accurate readings on my gauge. Any tips eliminating air would be appreciated.
Old Sep 27, 2007 | 09:52 AM
Fisherguy's Avatar
After reading about all the problems people are having with the isolators I installed mine without one, used a needle valve instead. Pics, part no's tc in my gallery.
bpollard1248
Dec 31, 2007 01:57 PM
Random Acts
Dec 16, 2007 02:04 AM
65pacecar
Oct 1, 2007 09:18 PM
66fordcrewcab
Mar 21, 2007 01:47 PM
deezulsmoke
0
Mar 21, 2005 09:59 PM
