isspro FP ?
Old Feb 22, 2005 | 10:10 PM
upersleder's Avatar
isspro FP ?
i called geno's today to order gages, they said they do not sell the isspro EV fuel pressure gage because its not reccomended for diesel. WHATS UP WITH THAT? so do i have to go with a whole different set? i wanted to use a mechanical gage.
Old Feb 22, 2005 | 10:15 PM
phox_mulder's Avatar
They'd better be, as that's what I'm running, Diesel going right to the back of the guage.
I know Isspro's had a major backorder problem, but other than that.
phox
Old Feb 22, 2005 | 10:41 PM
mkubacak's Avatar
I got mine from West Texas Diesel.
http://www.westtexasturbodiesel.com
Old Feb 22, 2005 | 11:28 PM
infidel's Avatar
I think the problem Isspro was running into was their isolator, just don't use it.
Old Feb 22, 2005 | 11:40 PM
CORed's Avatar
I just checked out the West Texas site and didn't find an answer I was looking for. What is the pressure range of the Isspro EV fuel pressure gauge that you have mkubacak?? Are you using an isolator or straight to the gauge?
I have two other Isspros (boost and EGT), but I have a Westach electric fuel gauge. Obviously, it doesn't match so I'm interested in the range of the EV you guys have for fuel.
Oh, and how long have you had them in operation?
Thanks!
Steve
Old Feb 22, 2005 | 11:52 PM
joefarmer's Avatar
30psi ISSPRO EV, no isolator, 9 months, no leaks or problems. It even got pounded when the needle valve accidently got set wide open for a 500mi towing trip.
brandon.
Old Feb 23, 2005 | 08:28 AM
gandrews's Avatar
I have the 0 to 30 psi ISSPRO - over a year 10k+ miles no issolator no problems.
I understood it is rated for diesel when I purchased it - but did not independently verify that.
George
Old Feb 23, 2005 | 08:46 AM
Dr. Evil's Avatar
Guys, inside a pressure guage is a device called a bourdon tube. It is the pressure sensing device. The Bourdon tube is essentially a thin hollow tube made of metal and is directly connected to the pointer. So, I dont understand how they can say its not made for "diesel". To my knowledge, diesel isnt particularily harmful to metals. I think they were takling about the isolators....the diaphrams are not made for diesel applications and do not last when used with diesel.
Old Feb 23, 2005 | 09:00 AM
Troublezilla's Avatar
Is the needle valve a must? Or can you get by with out it. I ran mine from the bottom of the filter straight to the guage using 1/4" stainless braided teflon hose. Anybody else use this set up.
Old Feb 23, 2005 | 09:14 AM
Dr. Evil's Avatar
The needle valve or a grease gun hose is a must....some guages only last a few hours without it.....you need to dampen the pulse from the VP-44.
Old Feb 23, 2005 | 09:19 AM
upersleder's Avatar
hmmm would an air arrester work? the type used on household water systems for washing machines and dishwashers? one could easily be plumbed in to the fuel gage line to dampen any pulses.
Old Feb 23, 2005 | 09:45 AM
My truck has rubber hose between VP and filter canister where I connected to. Would'nt this hose dampen the pulse.
Old Feb 23, 2005 | 09:52 AM
sammy198's Avatar
I just made sure and left a bunch of air in the line. It comes straight off the bottom if the filter canister with a taped banjo bolt.
There is no noise or vibration of the gauge. It has soild smooth sweeps when the pressure drops on hard acceleration and when it comes back up.
Old Feb 23, 2005 | 10:01 AM
infidel's Avatar
Some 24 valve fp gauges pulsate, others don't. Some pulsate right away, others after any air in the line is displaced by diesel which always happens eventually. One thing's for sure though, pulsation will kill a electrical sender or mechanical gauge. Adding a $4 needle valve to the setup is cheap insurance.
An air arrester would work but would cost more and take up more space.
Old Feb 23, 2005 | 10:04 AM
Dr. Evil's Avatar
a pressure snubber will also work - but again, will cost more than the needle valve.
