Installing pyrometer probe.
Old Jan 12, 2007 | 03:08 PM
LuvmyCTD's Avatar
Dude...That's totally rad!!...what a concept..I've seen the mech's. do this down where I work...thought they were trying to get rid of a cold cup of cawfee...Hmmm....
Old Jan 12, 2007 | 03:34 PM
Fisherguy's Avatar
Okay, I get it, you hold the turbo so it can't spin, when you fire up the engine the particles blow past the turbo, cool!
Old Jan 12, 2007 | 04:23 PM
cLAYH's Avatar
Did mine 2 nights ago, started with a small bit and drilled almost all of the way thru, then moved to the final drill hole size. I stopped just before the bit was to break thru and then started the engine. I drilled slow for the last bit making sure to keep the drill straight. The mainfold is made of soft metal and very easy to drill thru. Breaking off a bit is highly unlikely unless you are really unfamilar with a drill. Chances are the bit would be held in the hole by the exhaust pressure anyway and not pushed thru the turbo.
Old Feb 19, 2007 | 06:26 PM
Truckman's Avatar
Question Pre Turbo
Question?? I you guys put the pyro before the turbo,,Has anyone heard of the tip breaking off the sensor and going thru the turbo?? If it was post turbo it would just go down the exhaust,,Of Course I dont know if they are known for breaking or not I am just asking cause I am getting ready to install one myself...
Thanks
tomd
Dec 12, 2006 10:56 PM
Lenn
Mar 24, 2006 08:55 PM
TinJim
26
Sep 19, 2005 11:58 PM
GaCamper
Sep 5, 2004 08:40 AM
Homestead
Feb 9, 2003 03:14 AM
