installed my dana lock right today...
Old May 9, 2005 | 06:48 PM
MKELLY's Avatar
How do you tell which type of limited slip you've got, 98.5 with a dana 70?
Old May 9, 2005 | 06:55 PM
Only one kind in the Dana 70 and 80, Powr-Lok.
Old May 9, 2005 | 07:06 PM
MKELLY's Avatar
Thank You Sir
Old May 9, 2005 | 08:14 PM
Fueling around's Avatar
back to original question of friction modifier:
If you go with a synthetic most are fine right from the bottle.
Don't get over zealous on adding modifier. Add an ounce or two and drive it hard to completely saturate the friction material. This is going to take a couple hundred miles.
Old May 10, 2005 | 12:44 AM
Barry St John's Avatar
jimjawz, Thanks for the info
Old May 10, 2005 | 10:17 AM
Flatty's Avatar
Start saving up for a new rear end. If the lock-wrong for the Dana 80 is ANYTHING like the ones for the Dana 60, you are gonna make SOOOOOO much noise, and eventually they will snap the shafts. If you want a true locker in ther,e spend the skrill and get yourself a Detroit. The Lock-Wrong replaces ONLY the side gears, and not the carrier. It works great for a front axle, but it will wreak havoc on your rear end. Your head will hate you for it too. I have been rockcrawling for over 10 years now, and you can hear that rear end coming froma mile away... Clang, Bam, Clang, Bam...
DIma
Old May 10, 2005 | 10:43 AM
jimjawz's Avatar
flatty, I installed a powr-lok and not a lock-wrong . I miss addressed the heading on this post.
ST.john, your welcome.
I did a full second gear drift today...right in front of a cop!! I told him that it has a brand new LSD. He let me go with a warning.
Old May 10, 2005 | 10:56 AM
Stamey's Avatar
Old May 10, 2005 | 11:38 AM
CTD NUT's Avatar
Old May 10, 2005 | 01:35 PM
jimjawz's Avatar
I think the guy thought my truck was cool. Way too close to be funny
Old May 10, 2005 | 03:52 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
Actually the4re are two kinds from DC. in 1998 was teh change over and phasing out of the power lok. the latter versions use the same visually exterior bolt together case but the interior is machined and installed with Trac lok components.
Whole different animal
SkyHarborCowboy
18
Apr 21, 2009 10:11 PM
catnfool
Dec 31, 2006 11:35 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
