installed a dodgezilla turbo WOW!!
Like the title says I installed a dodgezilla on the truck and kept the 12cm housing. This thing rocks! The stock turbo would billow black smoke with the 6 plate full forward. Now The exhaust would probably pass in a tree hugger convention. The spool up is awesome to boot.
I took the truck to the 1/8 mile track tonight. Very slick conditions. I managed high 11's at 65MPH spinning the tires all the way into 4th gear. Even dumping the clutch in third boiled the hides. The first pass I layed rubber all the way throught the traps till I hit the brakes. I couldnt even get traction fluttering the throttle. I believe 75 MPH at 11 flat is totally possible I am just so excited I had to share.
Originally Posted by BCB
When you drag race in 4 wheel drive do you shift out of 4wheel drive or run it all the way down the track in 4 wheel drive?
No I didnt run in 4x4. Thats just a little to much abuse on the old girl. With traction I would definatly be in 5th gear. As it was I was pretty much sitting at 3200 RPM the whole time.
Shawn.L.Turbo
07-16-2007 06:21 PM
JaMan
03-07-2004 05:24 PM
