input on exhaust manifold
Old Feb 19, 2010 | 11:13 AM
Diesel Demon's Avatar
I am upgrading my truck. with head studs and bigger turbo. I would like a little info on what exhaust manifold I should install on the truck. any info would be a great help. And yes I do want to here everybodys 2 cents worth LOL Thanks in advance for the info Garry
Old Feb 19, 2010 | 01:47 PM
Brendan's Avatar
Get the aftermarket 3 piece high flow unit, it's worth it. Especially with a bigger turbo, you should notice a little better spooling and lower egts. My 2 cents.
Old Feb 19, 2010 | 02:10 PM
Tate's Avatar
I never noticed any change on my 24v. Only reason I bought one was because the manifold split. I've heard they make more of a difference on a 12v, but from my experience with the 24v, I'll put my $450-600 to better use elsewhere.
Old Feb 19, 2010 | 03:32 PM
DodgenIt's Avatar
I dont have one, but I plan on gettin one when I do compounds, biggest reason is cause Ive heard the 1 piece stock one is known to crack and warp.
If you have the money, go for it, other wise, maybe hold off.
On the othe hand, if you tearin into it to do studs and turbo, could do 3 piece mani at the same time.
My .02
Old Feb 19, 2010 | 03:45 PM
RowJ's Avatar
01's and 02's have better stock manifolds than earlier years. Better metalurgy. Can't remember anyone having cracks.
I don't think the after markets make a big difference on 24v's. Not considering the price.
They are, however, stronger and do flow a bit better. If money if a consideration, I'd pass.
If you can afford it and plan to keep the CTD a long time, it's worth doing. Especially if planning twins with the extra weight.
I bgt the HTT manifold and like it very much.
From what I've seen they fit better than the ATS. Don't need as much working to get them lined up.
RJ
Old Feb 20, 2010 | 04:05 PM
gforce's Avatar
Bullseye power now offers a stainless manifold to fit your truck.
silkywoods
35
Feb 6, 2008 12:40 PM
Joe Diesel
Nov 12, 2007 08:59 AM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
cummins dsl
Feb 14, 2005 03:11 PM
