Injector tools
Old May 12, 2005 | 10:15 PM
gcookieman's Avatar
Talking Injector tools
What tools do I need to replace injectors in my truck? Going bigger oh yes where do I get them? Thanks
Cookieman
Old May 13, 2005 | 12:06 AM
csutton7's Avatar
a friend who has all the tools and wants to do the swap is the best tool----
but you should be able to get by with the following--
8mm thru 19mm wrenches and sockets--a short 19mm wrench comes in very handy for injector line nut #6 although you can get by without it--a small flat screwdriver and some grease to lube the orings on the new injectors--that should get you real close---some use a torque wrench to tighten things---chris
Old May 13, 2005 | 09:13 AM
gcookieman's Avatar
Thanks cssutton7 I already have the injectors new I just wanted everything togther before I start I have the torq wrenches so thats no problem .
Thanks Cookieman
Old May 13, 2005 | 09:35 AM
Bob Wagner's Avatar
check out this link
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
Old May 13, 2005 | 10:05 AM
gcookieman's Avatar
Wow Bob excellent exactly what I needed thanks my manual doesnt say all this and I knew there was more to it than what I could see.
Thanks again
The Cookieman
Old May 13, 2005 | 02:24 PM
Mike D's Avatar
I found using a wonder bar to pop out the back injectors works great, too. Sometimes is hard to get those bent needle nose pliars in the right position.
Old May 13, 2005 | 05:41 PM
gcookieman's Avatar
Thanks Mike just came in after a test drive with my bosch inj the superchip on safe tow man the inj on these trucks are a huge upgrade. I dont know what inj I got but the guys at Acme diesel here in Knoxville TN told me they would wake my truck up . That my friends is an understatement.
Thanks to all
The Cookieman
ataboy9026
Jun 7, 2006 10:27 PM
kawi600
Jan 26, 2006 10:19 AM
mopar2ya
14
Jun 23, 2005 12:29 PM
Mcmopar
Mar 8, 2004 09:08 PM
Nov 4, 2002 12:03 PM
