Injector$?
Old Jan 23, 2007 | 10:03 AM
Rocky5.9's Avatar
Injector$?
I have been reading many threads this morning on injectors. I have also been checking out the sites of different brands of injectors. Are they selling injectors one at a time for $300 and up, or is that a price for a set?
Old Jan 23, 2007 | 11:05 AM
Buckshotram's Avatar
It should be for the set.
Old Jan 23, 2007 | 12:58 PM
Rocky5.9's Avatar
I hope so. I don't even know if I should be in the market to buy injectors yet, but if that was only for one I could not justify $2000 for an upgrade...unless it came with a good looking woman to help install them.
Old Jan 23, 2007 | 01:02 PM
Mike D's Avatar
Depends on which injectors you're looking at... F1 Diesel's biggest sticks are around $200/injector. A set (6) of RV275 are around $300.
A set of RV275s cost around $6-7.00 per HP assuming you get 40 to 50 hp gain.
Here are the $/HP numbers for Don's line of injectors.
Mach 1........$9.23/HP
Mach 1.6.....$7.77/HP
Mach 2.......$7.61/HP
Mach 3.......$6.92/HP
Mach 4.......$6.00/HP
Mach 5.......$5.00/HP
Mach 6.......$5.45/HP
Mach 7.......$5.41/HP
Looks like the Mach 5s are the best bang for the buck.
Old Jan 23, 2007 | 01:04 PM
Rocky5.9's Avatar
Is there a site to check those out at? Don'sdiesel.com?
Old Jan 23, 2007 | 01:08 PM
signature600's Avatar
www.f1diesel.com
Then find the dealer closest to you and give them a shout. Don doesn't deal direct, but his dealers are VERY knowledgeable!!!
Chris
Old Jan 23, 2007 | 01:10 PM
vciesielski's Avatar
Here it is!!!!!! F1 Diesel
Old Jan 23, 2007 | 01:16 PM
Rocky5.9's Avatar
Thanks Guys. I checked the site out. With the Mach 3 would I "need" a larger turbo...or is even the Mach 2 pushing the edge on the stock turbo question?
Old Jan 23, 2007 | 01:36 PM
Mach 2's and a Comp=EGT trouble when you're pushing on it!
IMO,
Chris
Old Jan 23, 2007 | 01:59 PM
Mike D's Avatar
Get the 4's if you're looking at the 3s...
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
