Info on Turbonetics CTD chargers here..
Old Aug 23, 2007 | 08:16 PM
HOHN's Avatar
OK fellas, I called T-netics and got the turbo info that they ought to have on their website (no map though-- phone, y'know).
There are two chargers, the "Stage 1" based on a T58, and the "stage 2" based on the HP66. The "stage 3" that's on some sites and web boards won't be placed in production. It's vaporware and you can't get one.
On with the specs:
T58- Stage 1
Comp Inducer: 2.3"/58.4mm
Comp Exducer: 3.304"/84mm
Turbine Inducer: 2.92"/74.1mm
Turbine Exducer: 2.542"/64.5mm
Turbine housing: .70 A/R
Flange: T4 divided (yes, it comes with an adapter)
Turbine outlet: 4" V-band (woohoo!)
HP66- Stage 2
Comp Inducer: 2.58"/65.5mm
Comp Exducer: 3.584"/91mm
Turbine Inducer: 3.111"/79mm
Turbine Exducer: 2.693"/68mm
Turbine housing: .84 A/R
Flange: T4 divided (also includes adapter)
If you calculate the trim on these compressors, you can see they are fairly low, and should handle higher PRs pretty well. The stg 1 is on the map up to 40psi, and the stg 2 up to 45psi, according to their tech.
No selection of turbine housings is available-- you either take it or leave it.
The stg1 looks like it would be a great towing turbo-- nice open hot side to let it breathe.
Justin
Old Aug 23, 2007 | 11:58 PM
Ph4tty's Avatar
t-58
Old Aug 24, 2007 | 12:10 AM
Ph4tty's Avatar
And hp66 is a compressor wheel used in their gt-k line
Old Aug 24, 2007 | 02:10 AM
HOHN's Avatar
You've been holding out on me!
Maybe we should look at the GT-K?
Sweet!
jh
Old Aug 24, 2007 | 07:26 AM
signature600's Avatar
Sweet!
jh
They told Joefarmer the GT-K's were a marketing ploy for the import crowd, and to stick with the HP's
Chris
Old Aug 24, 2007 | 10:19 AM
timbeaux38's Avatar
There is also a T-61 and a T-64. Call Dynomite. They have run every TN turbo out there, and can tell you what works best for your application.
Old Aug 24, 2007 | 10:48 AM
Lil Dog's Avatar
Isn't 55 lb/min a little low? From the calculation maps I have seen for over 400 Hp you need anywhere from 60-62 Lb/min flow...
Old Aug 24, 2007 | 01:57 PM
HOHN's Avatar
Not with the assumptions I made. the 500hp I want needs 73 lb/min.
62lb/min is enough for ~425hp with perfectly manageable EGTs (<1200) and no smoke at all.
This assumes BSFC of .4 and afr of 22:1-- pretty clean.
JH
Old Aug 24, 2007 | 02:09 PM
chrleb1's Avatar
No they weren't. They were a mistake.
Chris
Old Aug 24, 2007 | 03:07 PM
Ph4tty's Avatar
No just a good friend of google
Ouch on prices: http://www.turboneticsinc.com/produc...category_id=99
bansh-eman
Jun 3, 2010 08:13 PM
mainer
Sep 20, 2007 03:43 PM
dIlLiGaF
Dec 4, 2004 02:17 AM
cmnspwr
Sep 14, 2004 02:05 PM
pappyman
50
Jan 10, 2003 09:11 PM
