comp wheels on 62mm chargers
Old Sep 20, 2007 | 11:17 AM
mainer's Avatar
looking for pictures of compressor wheels on 62mm compressor turbos...
specifically the HTT super stock 62.
I'm trying to find out what exactly the turbo is my friend has. Its a BD turbo for a duramax and i know it has a 62mm comp wheel, just not sure on what wheel it is and also trying to find out what hotside it is.... (seeing if it will work in my 12v)
any help would be great thanks...
Old Sep 20, 2007 | 12:00 PM
PourinDiesel's Avatar
Hot side is probably about 60mm @ the exducer.
Old Sep 20, 2007 | 12:16 PM
mainer's Avatar
trying to compare it to the HTT turbo's made for the cummins... so would it compare to a 71 or a 65 in the HTT's and any idea on how to find out the hotside housing size??
trying to see if this will work on my 12v...
Old Sep 20, 2007 | 02:54 PM
kantdrive55's Avatar
DTR Advertiser
[QUOTE=mainer;1704661]looking for pictures of compressor wheels on 62mm compressor turbos...
That turbo would be equivilant to our Super B Special turbo which will probably be a little too much turbo for what you are running especially if you tow heavy or are running a tight conveter. The A/R ratio is .80 and it will flow 1150cfm.
Old Sep 20, 2007 | 03:43 PM
duratothemax's Avatar
definetly wont work :
bansh-eman
Jun 3, 2010 08:13 PM
HOHN
Aug 24, 2007 03:07 PM
dIlLiGaF
Dec 4, 2004 02:17 AM
cmnspwr
Sep 14, 2004 02:05 PM
pappyman
50
Jan 10, 2003 09:11 PM
