Solar panel chargers
Old Dec 2, 2004 | 04:31 PM
dIlLiGaF's Avatar
I was able to aquire a solar panel battery charger from a garage sale, and was hopeing someone could advise as to wheather or not It could do any damage to the trucks electronics? The specifications on the back of the panel are as follows.
Max power:3.2w
Voltage at max power:18.8v
Current at max power:170ma
I hopeing to use this device to keep the battery's charged up during the day will at work.
Thanks
Old Dec 2, 2004 | 05:12 PM
ramtd02's Avatar
that will not hurt your battery(s). The power output of a solar panel are so little that the battery(s) will not be effected. I take it though that you are using power through your batteries while at work...because realisticly you shouldnt need a charger unless the batteries are dead
Old Dec 3, 2004 | 01:32 AM
RAFTEN's Avatar
3 amps won't do to much to bring a battery back up but will help maintain them.
Old Dec 3, 2004 | 03:22 AM
AlpineRAM's Avatar
I'd say that you should get a voltage limiter for 14.4V too- even though 170mA won't really cut it except for a minute trickle charge. If you want to run equipment like an espar heater the solar panel won't be enough.
AlpineRAM
Old Dec 4, 2004 | 02:17 AM
dalton4's Avatar
Don't expect to get max power output. Those values are for perfect conditions which you most likely won't have. Even perfect conditions would be short lived due to movement of sun.
Scotty
May 3, 2011 10:59 AM
waam
Aug 11, 2007 11:21 AM
cmnspwr
Sep 14, 2004 02:05 PM
Casey Balvert
May 27, 2004 05:32 PM
pappyman
50
Jan 10, 2003 09:11 PM
