I need gauges, which ones?
Old Jan 13, 2007 | 01:16 PM
chiefallred's Avatar
Exclamation I need gauges, which ones?
OK, learning alot from the websight. I now know i need to install a fuel pressure guage and monitor pressure to stay above 5psi.
what other gauges would be of GREAT benefit. I have heard of monitoring the exhaust temp. why? any others.
thanks
Old Jan 13, 2007 | 01:55 PM
b.lee's Avatar
I have the fuel pressure gauge you need...
0-30 psi.
and if your EGT's get too high, you can melt the top end of you engine.
Old Jan 13, 2007 | 01:58 PM
thanks b.lee
what should the egt's run or should i ask the max
Old Jan 13, 2007 | 02:52 PM
b.lee's Avatar
lower the better.
i'd say try to stay low as possible.
edit: you want a fuel pressure gauge ? 0-30 psi, pefect for yorur truck.
Old Jan 14, 2007 | 10:51 AM
REF>Lancer's Avatar
Originally Posted by chiefallred
thanks b.lee
Keep it under 1150f before the turbo,at least pulling a load,I don't think you'd want more than about 1350f for very long (Drag racing)..I don't race so I could not tell ya for sure
I melted my piston,at about 1300f for about 2 minutes.(A nice golden brown)
Old Jan 14, 2007 | 12:45 PM
XLR8R's Avatar
Could you fill out your sig, Chief?
Old Jan 24, 2007 | 07:32 PM
found some resonable priced gauges if anyone is needing
GLOWSHIFT GAUGES 1-888 GS-GAUGE
MON - THURS 12-8 FRI 12-6 EST
Old Jan 24, 2007 | 07:47 PM
scottsjeeprolet's Avatar
You should get the fuel, EGT, & Boost. If you have an Auto you'll need a trans temp guage as well. Check out my pics in my gallery. Those are the Isspro New Dodge White from Genos garage.
Old Jan 24, 2007 | 08:11 PM
Muddin_dude06's Avatar
Check out PureDieselPower.com they have all the gauges you need from several different manufacturers and Garrett is a great guy to do business with. Pretty much the standard gauges are EGT, Boost, and fuel PSI and then the Tranny temp if you have an auto. I personally LOVE my Optix made by Diprocol, I think they mesh with the factory gauges very well.
Mexstan
Dec 2, 2012 06:28 PM
JOECUMNS
28
Mar 1, 2007 08:15 AM
Booger
Feb 14, 2006 01:28 PM
hunterrj
May 27, 2005 12:46 PM
Tim9712v
Jan 24, 2005 05:22 PM
