I need gauges, which ones?
OK, learning alot from the websight. I now know i need to install a fuel pressure guage and monitor pressure to stay above 5psi.
what other gauges would be of GREAT benefit. I have heard of monitoring the exhaust temp. why? any others. thanks |
I have the fuel pressure gauge you need...
0-30 psi. and if your EGT's get too high, you can melt the top end of you engine. |
thanks b.lee
what should the egt's run or should i ask the max |
lower the better.
i'd say try to stay low as possible. edit: you want a fuel pressure gauge ? 0-30 psi, pefect for yorur truck. |
Originally Posted by chiefallred
(Post 1297811)
thanks b.lee
what should the egt's run or should i ask the max I melted my piston,at about 1300f for about 2 minutes.(A nice golden brown)[duhhh] |
Could you fill out your sig, Chief? :)
found some resonable priced gauges if anyone is needing
GLOWSHIFT GAUGES 1-888 GS-GAUGE MON - THURS 12-8 FRI 12-6 EST |
You should get the fuel, EGT, & Boost. If you have an Auto you'll need a trans temp guage as well. Check out my pics in my gallery. Those are the Isspro New Dodge White from Genos garage.
Check out PureDieselPower.com they have all the gauges you need from several different manufacturers and Garrett is a great guy to do business with. Pretty much the standard gauges are EGT, Boost, and fuel PSI and then the Tranny temp if you have an auto. I personally LOVE my Optix made by Diprocol, I think they mesh with the factory gauges very well.
