hx40
Old Mar 28, 2004 | 11:30 PM
ZUNK's Avatar
Question hx40?
Doe's anyone here have a PDR HX40? If so what is the model no. on the tag? I think someone gave me one . It has a holset tag 'but it is not the same as my HX35(there is no holset part nos. Just a model no.[ hpdr35xxxxx HX40W ]. Is this a PDR turbo?
If so I wonder if I would benefit from it. With a load I run 40psi and 1250 deg. (I dont let it get any higher) up hill. I have more throttle left but can't use it for temps. I have A cone filter,4" exhaust, 1.47mm timing, two turns on the fuel screw, and a modified afc cone.
Old Mar 29, 2004 | 07:39 PM
bigred496's Avatar
if you have an hx35 you can give it to me
Old Mar 29, 2004 | 07:49 PM
Haulin_in_Dixie's Avatar
Re: hx40
I certainly am no exper on this but I believe you have a stock HX40 with waste gate. You need to look and see if the exhaust manifold flange is the same size as yours. It may be larger.
Old Mar 30, 2004 | 02:12 PM
ZUNK's Avatar
Bigred; I'll let you know something when I decide what turbo I'll use.
Dixie; This turbo has a small flange 16cmW hossing. The ID tag says holset but is different from all other holset tags.
Hawkeye
Sep 23, 2003 08:22 PM
hellotbone
16
Jan 13, 2003 02:03 PM
21
Dec 3, 2002 10:10 AM
shaft01
Nov 22, 2002 08:46 PM
chevota01
Nov 12, 2002 05:10 PM
