hx35 off of a 24 valve and put on to a12 valve
Old Aug 26, 2004 | 08:23 PM
jimjawz's Avatar
Question hx35 off of a 24 valve and put on to a12 valve
I have a buddy with a totally stock 93 250 ram and I was wondering if my old waste gated hx35 would fit or even make a differance? My truck has the ho engine and the old turbo already has a four inch down pipe. Any suggestions would really help
jim
Old Aug 26, 2004 | 10:44 PM
Forrest Nearing's Avatar
if his truck is pretty mild, it'll work well
Old Aug 26, 2004 | 11:20 PM
jimjawz's Avatar
will the exhaust bend fit ? the down pipe on the truck has a more agressive bend in it than that of mine.
Old Aug 26, 2004 | 11:24 PM
you'll have to mod the downpipe slightly. also, there were two different back plates for the HX35... one has a ~45* elbow w/ a two bolt flange... the other is a 3" v-band connection, and then they had a 45* elbow w/ a two bolt flange that banded to that.
if yours has a v-band connection, it won't be too bad. I think you have to add a couple inches to the first section of the downpipe.
Forrest
Old Aug 26, 2004 | 11:34 PM
jimjawz's Avatar
thanks for the advice. Is it worth doing or is it a lost cause?
Old Aug 26, 2004 | 11:41 PM
it depends on what he uses the truck for... the turbo will spool up much quicker, but it won't have as good of a top end charge I don't think... tough to say... the increased boost might allow it to pull better on the big end too. I'd probably do it just for the hell of it.
Old Aug 27, 2004 | 04:14 PM
The HX-35 works awesome on a 1st gen! Like Forrest said, if you have the v-band backplate it's real easy. All you need to do is move the downpipe back or shorten it about 1.5 inches. I have a WH1C (functionally identical to an HX-35) off a '94 on my truck and I love it. Everything got better when I put it on, especially turbo lag. Wish I had a buddy like you, I had to buy my turbo off Ebay.
Old Aug 27, 2004 | 04:17 PM
if you need a v-band backing plate, I've got one laying around somewhere.
Old Aug 27, 2004 | 04:37 PM
This kind of stuff is what makes DTR so great.
Old Aug 28, 2004 | 10:24 AM
jimjawz's Avatar
WOW fellas thanks alot.I told this guy that I would ask DTR for some advice and like I thought,I got plenty.I only wish that I knew more guys that had big bad Cummins truck around here.I just moved in to my new house and I am here all alone. Thanks for the help DTR.
gaberichison
Dec 23, 2014 05:37 PM
jmd4993
Sep 18, 2013 03:09 PM
barngal6
Jul 5, 2009 06:49 PM
Smokin98.5
Jun 1, 2007 09:12 AM
ClawHammer
Aug 7, 2004 08:49 AM
