hp rating with these mods ?
Old Mar 11, 2007 | 07:45 PM
00 big boy's Avatar
I have a 2000 24 v with an edge comp, 110 hp BD injectors, AFE intake, straight pipe, and Southbend con fe single disk clutch. Truck runs awesome but never have put it on a dyno. Just wondering if anyone out there is runnig the same mods and if so what kind of horses are you seeing
Old Mar 11, 2007 | 07:47 PM
mysterync's Avatar
I would think your safely in the 400-450 range give or take!
Make sure you have a good fuel system behind those sticks!
Old Mar 11, 2007 | 08:03 PM
Tiger Rag's Avatar
400 sounds about right. Maybe a touch over. Also depends on the dyno.
I think I did 390 with an Edge Comp and Mach 1.5's. Mach 1.5's are about 85-90 hp injectors if I remember correctly. This was a Dynojet.
Old Mar 11, 2007 | 08:51 PM
SuperDave4x4's Avatar
If your running a stock turbo then your not getting to use all of you fuel.
Old Mar 11, 2007 | 09:37 PM
mysterync's Avatar
Good Point, But I wouldnt think a stocker would last long at that rate! I think we were figuring on a upgraded charger! It wouldnt be a very safe venture to run that much fuel on a stocker!
Old Mar 11, 2007 | 10:53 PM
00 big boy's Avatar
Thanks guys, I am running a stock turbo and havent experienced any problems yet. I do have to watch my etg's and have thought of putting on a bigger charger but dont know which charger would be best for this horsepower application. Any suggestions would be appreciated.
Old Mar 12, 2007 | 08:57 AM
mysterync's Avatar
The HTT 62 (12 or 14) would be a great charger! The SPS 62 (12 or 14) is also a great charger! That stocker is holding you from your goals!
wcbcruzer
Apr 2, 2007 03:48 PM
Evildiesel
Nov 18, 2005 11:29 AM
Igor
16
Aug 31, 2005 06:40 PM
bws
Apr 11, 2005 07:52 AM
stonewalldiesel
Jul 13, 2004 01:13 AM
