How not to Defuel
[QUOTE]Originally posted by greenworks
The 3-4 shift on the 47RE is controlled by the computer. You can put in a switch that will make the trans shift when you throw the switch (actually shortly there after). It's not a TC lockup switch, but controls the 3-4 shift. I throw my switch at about 2600, and it shifts about 2800. With the drag comp it reduces the amount of de-fueling between 2700-3200, but how long the engine is at 3200 before the trans shifts varies. The switch fixes that problem.
Paul
Originally posted by paulb
On a different note, you would be better off to put a 3-4 switch, so you can get it to ship before 3200.
Paul [/QUOte
I not sure what your trying to say?
Paul [/QUOte
Paul
Originally posted by ratsun
Thanks Brandon, do you have a graph with the Drag comp?
That graph totally reflects whats happining to my truck
of course at about 200hp less
Brandon what is the best 1/4 mile time you have run, our trucks are both 5-speeds but you have 175hp more than me, I have never run the 1/4 before but I would lkike to figure out where i would run I am guessing low 15's maybe high 14's. Can you feel the differnce with the drag comp, being the rpm is higher does it hold boost better when shifting?
brandon.
masonic-dodge
Feb 8, 2006 05:58 AM
big jimmy
Jan 23, 2006 02:53 PM
hellotbone
Aug 27, 2003 03:26 PM
