How to install theromcoupler for pyrometer???
Old Jan 6, 2009 | 12:44 PM
Lil Dog's Avatar
My point was even after I fished around with a magnet and used all the chip control methods, If I did happen to miss on little piece it shouldn't be a problem.
Old Jan 6, 2009 | 09:29 PM
Tate's Avatar
Originally Posted by JHew84
I would be leery of any method that involves blowing the shavings through the turbo, whether it's spinning or not. I'm sure it's worked fine for people in the past, but if there's other, safer, methods available why even bother?
We are not dealing with tight clearances, or high RPM at that point, nothing is gonna get hurt with chips going through the turbo. Long curls would be a bad idea, but a couple chips is nothing.
Old Jan 7, 2009 | 03:38 AM
JHew84's Avatar
I agree the likelihood of something happening is slim (but not none), and even acknowledged the other methods have worked for other people, but why risk it if you don't have to? Especially considering just letting the engine run while drilling/tapping the manifold will take the least amount of time out of all the suggestions, and is arguably the safest method.
Just my opinion, take it for what it's worth I guess, just seemed like a no brainer to me when I did the install on my truck...
Old Jan 7, 2009 | 08:24 PM
Lil Dog's Avatar
Engine running? I am a heat pansy!
Old Jan 7, 2009 | 10:06 PM
Tate's Avatar
For about the first minute, the exhaust was barely warm, let alone hot. By the time I got to tapping the hole, it was getting warmer, I just put a glove on and and carried on.
Old Jan 7, 2009 | 10:10 PM
MoparNut's Avatar
Originally Posted by high bid
loosen all the bolts attaching the turbo to the manifold insert a piece of cardboard in between the manifold and the turbo, drill and use all the advice from above for a happy ending.
I like this idea. So, by loosening the bolts on the turbo/manifold flanges the turbo will drop just enough, or will the exhaust pipe keep it from moving?
TinJim
26
Sep 19, 2005 11:58 PM
IH8MYCAT
Mar 13, 2005 04:24 PM
fordsmasher
Jul 1, 2004 07:01 PM
deere nut
28
Jan 12, 2004 12:22 AM
Push Rod
Oct 22, 2002 10:04 PM
