How hard is it to install a PacBrake? 60# Exhaust Valve Springs?
Old Jul 12, 2006 | 08:11 PM
Common's Avatar
Are there any exhaust brakes for a 12v that don't require 60#ers?
I hate downshifting, its so loud...
Old Jul 12, 2006 | 08:56 PM
Dr. Evil's Avatar
With a exhaust brake you will still have to downshift.
Old Jul 12, 2006 | 09:01 PM
Common's Avatar
Yeah, I just read that the engine needs to be at 2400 RPM to activate...
I'm never up there anyway...
Old Jul 12, 2006 | 09:08 PM
Dr. Evil's Avatar
actually the more rpm, the harder the brake works.
Old Jul 12, 2006 | 09:11 PM
Common's Avatar
I still have dumb questions about diesels...
Say I went from 5th to 3rd... would that screw anything up?
Bend some valves, huh?
I'm still learning, forgive me
Old Jul 12, 2006 | 09:12 PM
Clayten's Avatar
DTR's Toad Wrangler
I run my pacbrake 2000 rpm and under generally between 1500 to 1800 in fifth gear. If I am on a good hill I will go into 4th but that is because there are corners to negotiate. And that is at 11000 lbs. You can run a pacbrake in a 12 valve with the 30 lbs valve springs, you just don't put in the block in the second hole in the brake valve. But you would probably want the 60lbs springs it makes it a much better brake. It is not real hard to put the springs in just bring each cylinder to the top and let the valve sit on the piston as you go about putting the new springs in. The brake will activate at any rpm and can be used at idle and up 1000 rpm to speed up warm up.
Old Jul 13, 2006 | 02:47 AM
bgilbert's Avatar
Downshifting is hard on your clutch. It would really be bad if you went 5th to 3rd. The engine would most likely be fine though.
Are you just wanting to save $120 on the valve springs? Or half if you only got 6 of them.
Old Jul 13, 2006 | 09:18 AM
Clayten's Avatar
DTR's Toad Wrangler
[QUOTE=bgilbert]Downshifting is hard on your clutch. It would really be bad if you went 5th to 3rd. The engine would most likely be fine though.
Are you just wanting to save $120 on the valve springs? Or half if you only got 6 of them.[/QUOTE
6 valve springs is all you put in you just do the exauhst valves
ubet
13
Nov 18, 2011 11:50 PM
Jlaplante
Mar 29, 2011 10:22 PM
bob95065
Dec 10, 2009 08:37 PM
53 willys
23
May 19, 2008 06:14 PM
UnrulyNFS
24
Feb 21, 2008 03:16 PM
