How does a box change timing?
Old Jul 24, 2007 | 10:41 PM
GFB's Avatar
GFB
I'm aware of how most alter fuel delivery (tapped and not tapped), but how does a conservative box, such as the EZ, advance timing? School me.
Old Jul 25, 2007 | 03:22 PM
GFB's Avatar
GFB
Bump.
Bueler?
Bueler?
Old Jul 25, 2007 | 03:42 PM
Mike D's Avatar
I believe it alters the signal through the data plug. The ez plug into the data plug and the map sensor. The map sensor is used to modify fueling and the data signal is for timing advance.
Old Jul 26, 2007 | 08:26 PM
qzilla's Avatar
Yup, it modifies the "timing message" on the data bus to the pump. SOunds easy but, harder than you might think to change it.
Old Jul 26, 2007 | 10:50 PM
GFB's Avatar
GFB
Thanks. I just wanted to be sure that the ottomind was a fuel only module. It taps the pump wire and alters the TPS and MAP signals. That's it. So I think it's safe to say it doesn't do timing, which means it's safe to stack with a timing box.
Bowser50
16
May 1, 2010 04:58 PM
D45
Apr 9, 2008 05:27 PM
sledneck1
Sep 19, 2007 10:00 AM
Dusty Ratcliff
Sep 19, 2006 07:35 PM
BLUTIC
Dec 16, 2003 09:00 PM
