How to Determin Which Injectors I Have
Old Nov 4, 2008 | 05:33 PM
grover's Avatar
Is there a way to determine which injectors the previous owner installed on my truck. He said they are larger, but i would like to know which size they are and who makes them so when i go to replace them i know what size i was runnin before. With the drag comp and WH1C i can lay down some heavy smoke and EGTs climb quickly. Any advice would be appreciated.
Old Nov 5, 2008 | 10:05 AM
PaulDaisy's Avatar
I'm afraid that without records, you will have a hard time figuring that out. The only suggestion I have is, if the tips are 7-hole cone-shaped, most likely Jammers. If the tips are dome-shaped (like a hemisphere), they could be Machs (unlikely, the PO would have asked for a premium for you to keep them; at nearly $1k, they are too expensive to just "throw in" with the truck).
Bradleysram
19
May 12, 2009 08:36 AM
smokeum99ta
Dec 16, 2007 09:52 PM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
atc250r
May 12, 2003 02:56 PM
