Housing and DV's?
Old Sep 29, 2005 | 07:48 PM
doubleclick's Avatar
Housing and DV's?
1. I upped to a 14cm turbine housing with full expectations of a change. There was no change in spoolup, and I can still peg my 35 psi gauge, so not much of a max psi change. Temps cooled down nicely though, cruising at 100mph uphill is 1050* . Sould I go to a 16cm housing? I would like to get cruising boost down for milage, and max boost down to a more efficient range.
2. I have access to the DV's from a 215hp pump. Would it be worth swapping? Are they big enough to make a difference? Also, does it even help without bigger injectors? Thanks in advance
Old Sep 29, 2005 | 08:56 PM
SmokinFive9 4x4's Avatar
They definately would fuel more even without injectors, it would definately heat it up like bigger injectors would though. And I don't think it'd help with lower your boost #'s, it's more fuel, just like a bigger injector, basically it's still giving you a more unrestricted fuel flow and more fuel = more boost. Prolly not the best thing to do if you're going for less boost and less EGT's.
Old Sep 29, 2005 | 09:02 PM
Well you cant have your cake and eat it too. Looks like I'm going for more fuel, what else is there to do? Do you know what size the DV's would be? I was thinking 181's
Old Sep 29, 2005 | 09:08 PM
yes, 181's are stock in the 215 pumps. and once you go for more fuel, you'll never go back
Old Sep 30, 2005 | 05:14 PM
I know, you guys warned me. I said it would never happen to me, I could control myself, hahahah! I got the bug, my wallet is already empty!
Old Sep 30, 2005 | 06:28 PM
Jeremy Cusick's Avatar
I don't think the auto's in '95 had the same DV's, but I was told that my '95 came stock w/ 181's, since it's a manual tranny. any truth to that?
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
ClawHammer
Jul 16, 2004 10:38 PM
j
Jan 9, 2004 08:19 AM
HOHN
Dec 7, 2003 02:07 PM
