Horrible Fuel Mileage!!!!!!!!
Old Jun 21, 2007 | 08:23 PM
65fury's Avatar
im very dissapointed in the mileage im getting, i know i hotrodded it and everything, but still, i get 13mpg around town and highway, pulling 6k i get 10mpg, my truck has a 3 speed auto, 4x4, 3.07 gears, and 33inch tires plus all the performance stuff in my sig. why is my mileage so bad??? should i get that crappy of mileage?? thanks
jason
Old Jun 21, 2007 | 09:06 PM
Mike D's Avatar
The auto sans overdrive is hurting you. The big tires are hurting your mileage and possibly the lift to some degree.
Old Jun 21, 2007 | 11:40 PM
65fury's Avatar
i guess i figured the larger tires would of helped highway cruising speeds, guess i was wrong, any other ideas, before this motor my 1st gen motor got 16 highway and 14 around town. anyone have any other thoughts???
jason
Old Jun 22, 2007 | 04:02 AM
chuxtruk's Avatar
What kind of mileage do you expect to get with 445HP @ the pavement?? I have a mildly upgraded 300+ (underthehood ) hp rig and get a constant 21 driving back and forth to work. I don't think you can have that many horses and expect anything decent mileage wise. I think you can have one or the other (within reason) but both?? Oh sure, with your foot out of it but what fun would that be with a rig like yours???? But I agree with Mike.....ditch the 3 speed auto, along with those tires and you're off to a good start. That'll probably get you 4 or 5 more anyway. With a 5 speed (NV-4500) in there with that rearend you'd have a good Bonneville Salt Flats race truck that'd probably go 200 mph with that ratio....
Old Jun 22, 2007 | 05:38 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Tall and narrow tires can give better highway mileage.
Tall and Wide kills it.
Old Jun 22, 2007 | 06:04 AM
74dart's Avatar
Ok stupid question time...... How does that work is it the rolling resitence?
Old Jun 22, 2007 | 08:24 AM
zulusafari's Avatar
Yep -- rolling resistance. You have more friction in the contact patch to overcome, plus more weight.
Old Jun 22, 2007 | 01:09 PM
gmctd's Avatar
Put a 47RH in there with overdrive and lockup TCC - that should help - go to PATC for instructions with pics
Old Jun 22, 2007 | 01:57 PM
65fury's Avatar
darn i was hoping the mileage issue wouldn't be from the tries or lift, or the tranny, although i kinda figured the tranny was holding me back, so i thought taller tires would even things out, or not thanks for the help
jason
Old Jun 22, 2007 | 04:15 PM
HOHN's Avatar
Yes. Wide tires have a larger footprint and run lower tire pressure for a given footprint. Hence, more rolling resistance and lower mpg.
Look at wheels designed for maximum efficiency: train wheels. Hard? check. Thin? check.
The closer your tires are to a train wheel, the lower the rolling resistance.
Taller tires will produce taller overall gearing, and reduce rpm to help mpg.
The best tire for mpg would be something like a 225 size 19.5 from Rickson. But that's just for hwy mpg-- in town you'd probably do worse because they are so heavy.
Justin
Old Jun 22, 2007 | 04:26 PM
RowJ's Avatar
Have you corrected for speedo error from larger tires. If not, your getting better than you think...
http://www.sjdsm.com/tech/tire_size.htm
RJ
Old Jun 23, 2007 | 01:31 PM
65fury's Avatar
RJ
well to see if my speedo was off i drove 5 miles with my dad, me in my truck and him in his and his 5 miles were the same as mine, i noticed at his 5 mile mark i had only gone 4.8~9 miles so im only off by a hair. and actually before i lifted my truck i put these tires on and my mileage increased, with my old motor i got 16 around town with the taller tires i noticed i was getting more like 17-18 around town, but after i put the lift on my mileage dropped to a best of 14 around town and 15 highway. thanks
jason
Old Jun 23, 2007 | 05:20 PM
zulusafari's Avatar
Lifts hurt too, since they increase the frontal profile of the truck, increasing wind resistance. Not much, but you might be seeing something there, too.
Old Jun 24, 2007 | 07:47 PM
smokinstrokes99's Avatar
im with chuxtruk, that amount of hp with that trans and lift with wide tires will do that to millage.
Old Jun 24, 2007 | 09:28 PM
clarson80's Avatar
4.8 vs. 5 miles on your test...probably worth about 4%. Keep that in mind when your checking mileage #'s.
65fury
22
Dec 11, 2007 12:29 PM
robertc82
16
Dec 14, 2006 03:35 PM
STACKED
13
Feb 2, 2006 11:18 PM
quantrill88
Feb 6, 2004 11:30 AM
MARKY MARK
18
Feb 16, 2003 01:31 AM
