Holley Blue
Old Apr 17, 2008 | 09:58 AM
Mustang Eater's Avatar
Holley Blue
I did some reading on getting a lift pump and i heard alot about the holley blue??? I was wondering how well it worked on a diesel engine?
Also it came with a regulator, i dont need that do i? i should just run it straight without?
How do i run it? in between the fuel tank and the lift pump?
Old Apr 17, 2008 | 11:44 AM
Ron E's Avatar
The holly blue pumps, make around 15 PSI unregulated, I believe.
Old Apr 19, 2008 | 04:21 PM
rich's Avatar
mine is as close to the tank that i can get it. and i think its 18 psi and you dont use the regulator. easy to install
Old Apr 19, 2008 | 04:29 PM
DISTURBED's Avatar
or you ban buy a fass and get 18 psi at idle and 12 psi at wot
Old Apr 19, 2008 | 08:43 PM
tenbrooks's Avatar
Or you can install a single walbro and get 18-22 idle and 11 wot with out a regulator. goin with a holley is no different than the stock.
Old Apr 20, 2008 | 08:05 PM
Diesel Dummy's Avatar
I beg to differ, mine does 13-15 at idle and never goes below 11 at wot, before i adjusted the spring i was 20 at idle with a fresh filter. With it in tandem with the stocker i was 26 at idle and 18 at WOT. It is much better than the stocker.
If you do i recommend the big line relocation kit from vulcan, install will be much easier, and the bigger lines help. DD
Old Apr 20, 2008 | 09:43 PM
xtoyz17's Avatar
My procomp black does 17 idle, 16 cruising, 16 WOT on power level 10 with my adrenaline.
Might not be killer reliable, but for 140 bucks (that's pump AND money I have into my big line kit) I'll replace these things alllllll day long.
Old Apr 21, 2008 | 01:54 PM
When you hook up a pump do you bypass the stock lift pump? or go through it? When do i need to go to a 1/2 inch line?
Old Apr 21, 2008 | 01:58 PM
xtoyz17's Avatar
Pull the factory pump. You'll probably never need 1/2" lines, but the price difference was next to nothing, and everything was readily available so I said screw it and did 1/2".
Old Apr 21, 2008 | 03:23 PM
Big Blue24's Avatar
You can run through the stock pump in a series setup where you feed the stock pump with the Blue and get sufficient pressure without stretching the spring on the Blue.
In my opinion, that is just one more pump to go out and give you problems. Might as well eliminate the stock pump so you can steal it's wiring harness and simplify the install.
Old Apr 21, 2008 | 05:07 PM
Hey big blue thanks for the input.. It looks like you have a lot more stuff done then mine and you dont suck down the fuel? what is your pressure at idle? and at wot? have you heard of people bypassing the in tank pump?
Old Aug 3, 2008 | 05:38 PM
mmendiola's Avatar
There are two metalic and one black line coming from the tank. Which line do I need to cut and put the pump in?
Old Aug 3, 2008 | 09:50 PM
wurkenman's Avatar
Just follow the line back from the fuel filter inlet side.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
ET_178z
Jun 3, 2003 01:15 AM
cpermd
31
Nov 8, 2002 04:13 PM
