HO vs SO pump
Old Nov 2, 2008 | 09:37 PM
Krob's Avatar
HO vs SO pump
Alright so i am hoping that replacing my Apps will solve my current problem however inform me incase that does not fix the problem what are the advantages and disadvatages of an HO vs SO pump?
I beleive an SO is better for performace upgrades but i cant remeber why and i couldnt find anything in my searches.
THanks
ROb
Old Nov 2, 2008 | 10:11 PM
Flatbed24v's Avatar
I was told that the SO pump will fuel better in high hp application(500+)
Old Nov 2, 2008 | 10:43 PM
Krob's Avatar
Hmm, so in my 300hp set up what should i be getting if and when i have to replace my vp44. Also i have a fuel only box that i plan on installing some time in the near future so with that in mind what should i be looking at.
Thanks ROb
Old Nov 2, 2008 | 11:03 PM
Flatbed24v's Avatar
if you don't plan on going much over 350-400hp ( which is hard to stop once you get the bug) then get the one that is the cheapest, but if you want to take it to the max or if you have a feeling that you might get into the higher hp then go with the SO and it has been said that the SO will even out perform hrvp44 in the higher hp app.
Old Nov 4, 2008 | 10:46 AM
01smoker's Avatar
The SO pump has bigger plungers in it than the HO pump, so it will flow more fuel.
Old Nov 4, 2008 | 11:32 AM
AggieJustin's Avatar
With the SO pump, you'll pick up more top-end with the larger fueling boxes. But you lose some bottom end vs. the HO pump. Something like a Smarty or other fueling mod that adds more low-end helps make up the difference.
If you're never planning to go past 350-400, then you could get by with the HO pump. But if you want to go past, I'd switch to the SO so you can get max benefit out of any higher hp fueling boxes.
Old Nov 4, 2008 | 03:11 PM
Krob's Avatar
Hmmm thanks guys.
I dont think my pump is going out right now...hopefully but when it does i think ill get a so pump.....just in case i decide to go big....
Old Nov 4, 2008 | 09:07 PM
bridleman's Avatar
Go S.O same price more fuel to be flowed win win IMO
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
