high idler
Old Dec 28, 2002 | 10:45 PM
bishgeo's Avatar
high idler
where can I get one of these and how hard is it to install.
Old Dec 28, 2002 | 10:57 PM
Cold Diesel's Avatar
Re:high idler
Try this link high idler
I have one and it took me about 10 mins to install. All you need to do is remove the TPS (3 bolts) and plug it in. Then run the harness into the cab and you are done. Works great and I wouldn't be without it. Hope this helps
Old Dec 28, 2002 | 11:06 PM
mic646's Avatar
Re:high idler
Hey Cold - It says it will work on trucks up to 01. Does the same one work on O2?
Old Dec 29, 2002 | 12:18 AM
Re:high idler
Yup, works great on my 02, same plug ins. I love it in the winter ;D
Old Jan 5, 2003 | 04:22 PM
bishgeo's Avatar
Re:high idler
There has to be a better price on one of these than 200.00.That seems a little steep for a switch and a piece of wire. :-[
Old Jan 5, 2003 | 06:24 PM
gofastman's Avatar
Re:high idler
;DI use a 2 foot piece of 3/4 pvc pipe,<br>Place it between the throttle and the seat....High Idler.<br>Cost .50.<br>I can not take the credit on this....I got it from this board a few months ago.
Old Jan 5, 2003 | 06:52 PM
muddymess's Avatar
Re:high idler
harold bowers makes a fast idle device and sells for 35 bucks plus s &amp; h. it has worked perfectly for me and the price is right. just waitin for harold to hurry and get 1 out for the 03 crewcab i just got.<br><br>harolds email is rvhvnfn@juno.com .<br><br>if he doesnt answer for a few days its cuz he is havin fun in his rv<br><br>the ps is also a good device. had one and liked it. 200 bucks vs 35 bucks though and the idler from harold works just as well.<br><br>a fast idler is a goood idea and i dont like bein w/o 1 on the 03<br><br>
Old Jan 5, 2003 | 07:10 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:high idler
My Cummins 1400rpm Idle Controler.<br><br>Dimensions:<br>Length- 20.5 inches<br>Diameter- 1.5 inches<br>Composition- Pine<br>Cost- $0-zip-Nada-off the scrap pile. ;D
Old Jan 5, 2003 | 09:49 PM
ToolManTimTaylor's Avatar
From: Connecticut~ish Under the Hood of somethin&#039;
Re:high idler
<br>Shovelhead , Schweet!!! ;D Only Where does it plug in? and is that an infinate control unit (Power seat)
Old Jan 6, 2003 | 05:39 AM
Shovelhead's Avatar
Re:high idler
TTMT<br>It's pre set to 1400rpm.<br>measure, cut, measure, cut, measure, cut............ahh-haa 1400rpm.<br>The beautiful part is no batteries. ;D<br><br>However the Dylithium Crystals are getting harder to find. :{then there's that pesky matter*anti-matter thing.....}
Old Jan 6, 2003 | 06:59 AM
CTDCAL's Avatar
Re:high idler
Enlighten me guys,<br><br>This is my first diesel pickup and I was going to make a high idle stick but wondered if it was safe on the engine. I know the book says not to let the truck idle at start up and I just could not figure out how to defrost the thing on a cold morning so I could see out the windows. Is that what you guys are using the stick for? Having just come from a gasser, this was the only setback with the diesel, I used to like to let the truck get warm early in the morning, and this thing takes forever to warm up driving it down the road, let alone idling in the driveway. What is the safe RPM to idle it at when it is just started and still cold?<br><br>CTDCAL.
Old Jan 6, 2003 | 07:03 AM
Shovelhead's Avatar
Re:high idler
Morning,
My &quot;high idle&quot; stick is placed between the throttle pedal and the seat base about a minute after the oil pressure comes up. This gives me 1300-1400 rpm of idle speed to get the engine temps up quicker. I also leave the block heater plugged in until I'm ready to pull out as this further adds heat to the coolant reducing the warm-up time.
Old Jan 6, 2003 | 07:27 AM
Commatoze's Avatar
Re:high idler
[quote author=Shovelhead link=board=7;threadid=8910;start=0#88847 date=1041858192]<br>.....I also leave the block heater plugged in until I'm ready to pull out as this further adds heat to the coolant reducing the warm-up time.<br>[/quote]<br><br>I agree. The block heater is a great way to quickly warm the cab. I've found that 3 hours works good into the single digits, and provides enough warmth to start some defrosting of the windshield immediately. The engine sounds better when started and the grid heaters cycle in maybe 5 seconds so it's easier on the batteries too. I think everyone would agree though that the best way to warm it up, is to drive it.
brandon507
Oct 4, 2004 07:58 PM
Palmetto_kid
Feb 20, 2004 02:44 PM
Cumminsdude
63
Jan 7, 2004 07:51 PM
1320
May 20, 2003 04:30 PM
