High EGT'S
Old Oct 28, 2005 | 02:39 PM
  #31
CTD NUT's Avatar
The turn buckle is really a moot point if he already exceeds 20 psi in stock form - it isn't going to cause an egt drop.
Old Oct 28, 2005 | 02:40 PM
  #32
adidasman23's Avatar
Originally Posted by rjohnson
$2-4.00 at any hardward store. Need open ended hooks on both ends...and it needs either lock nuts or saftey wire it or it will vibrate loose.
Spring is optional...never had one myself. You can just lock the wastegate arm to the turbo housing and lock it closed. Your choice.
RJ
so when you put it on do you pull it towards the front of the truck or the rear.
Old Oct 28, 2005 | 02:43 PM
  #33
RowJ's Avatar
I'm thinking timing from the Comp....and the boost fooler, with the comp on 2x2 or so...will give a lot more boost than it will increase egt's????
RJ
Old Oct 28, 2005 | 03:04 PM
  #34
ib516's Avatar
Could there be a hole in the intercooler "charge cooler"?
Old Oct 28, 2005 | 03:13 PM
  #35
CTD NUT's Avatar
Even if he has a boost leak, there is more than a sufficient amount of boost in stock form to not have an egt issue.
Old Nov 2, 2005 | 08:26 AM
  #36
whazzup's Avatar
Just wondering if the depth of the thermocouple would cause an abnormal reading. If I remember right guages were changed out with no change.
Old Nov 2, 2005 | 03:57 PM
  #37
Gotlift01's Avatar
I would rule out the boost leak guess. Like CTDNUT said, you have more than enough boost exceeding the stock setting to cause any problems. Now if you were down around 14-15psi then yeah, you'd have a boost leak for sure!
I guess I'm still not seeing how the truck is pushing the 25-26 psi boost numbers without having something done to the wastegate...........after 20psi it throws a code and starts de-fueling right??? What kind of boost gauge do you have and where is it ported in at?
CTDNUT also said something about the possibility of maybe the ECM screwing with the timing, but I would rule that out now knowing that your truck doesn't smoke much.............if it smoked A LOT then that would be an excellent idea!!!!!
And as suggested above, how far down into your manifold is your probe?? If they are threaded in to far it usually makes them read funny.........not sure HOW funny but it's worth a shot to check it out.
~Nick
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Eat Beef
18
Mar 25, 2003 06:01 AM
gofastman
14
Jan 26, 2003 10:33 PM
