Help with turbo swap...
Old Aug 3, 2007 | 02:30 PM
SPLnut's Avatar
Not much lag here and she's driven daily...Gets up and goes (she can pour at will also)
Old Aug 3, 2007 | 02:50 PM
schoust's Avatar
I think the differance is the fact that you are running a stick with a 410 gear? I'm not so sure about an auto with 3:55's??
Old Aug 3, 2007 | 02:58 PM
dieselfan's Avatar
remember his location has a ton to do with it. its really humid down here and turbos like that.
Old Aug 4, 2007 | 08:00 AM
BigNasty4x4's Avatar
Originally Posted by dzlfarmboy
You coming to the Queen Anne's county sled pull/Dyno day Aug 11th?
I was unaware of such...I was planning on attending the drag/dyno event at Cecil, but if this is closer I might be in for that.
-Steve
Old Aug 4, 2007 | 03:25 PM
Oh...by the way, here are the results of yesterday:
Finally got it all apart, and got the new turbo in and the exhaust fitted and new pipe in to mate the new full 4" down pipe to the mbrp 4" exhaust with out cutting the old down pipe (for sale now if anyone is interested). Got the oil return bolted up, the turbo clocked properly, and hooked up the downpipe and the compressor outlet, primed the turbo with oil, and then when installing the oil feed line (which was the 2nd to last thing to do before I checked it over and started it back up, just needed to tigten up the mounting bolts) and the oil feed adapter ended up busting in half, leaving the threaded half in the center section.
Luckily, it was easily removed from the center section with a flat head screwdriver, but now I need to order a new adapter. Might just order a new oil feed line to go with it and be done with it.
Is there anywhere other than a Dodge or Cummins dealer to get the adapter? Hardware store possibly carry it? Hopefully somewhere that will have better chances of it being in stock. Maybe someone has a spare laying around the garage they can sell me?
-Steve
Old Aug 4, 2007 | 04:56 PM
SPLnut's Avatar
I'll check on a old turbo i have side somewhere and see if its still got the fitting
Old Aug 5, 2007 | 10:03 AM
That would be awesome! Thanks for checking...
-Steve
Old Aug 5, 2007 | 02:23 PM
Duh...I don't know why I keep typing HTB2, its not an HTB2, but an HT71 series, the Quick Diesel 64. Unsure where that came from...
-Steve
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
mtpil
May 27, 2008 01:00 PM
mtpil
May 26, 2008 05:13 PM
