Help! I got a dirty turbo!
LPS No Flash NU is the best stuff out there. But its $30-$45 a can. Brake clean or contact cleaner should work. Spray down, wipe off. Take the compressor housing off when you do this if you actually want to clean anything.
No need to take the housing off, Just use the brake clean or Carb cleaner and a soft bottle brush. It will be a little tough to get in there but you will be able clean it very well. You will want to remove the compressor outlet hose so you do not wash any debris into the inner cooler. You can then rinse it out with a lite spray from the garden hose then put it all back together.
ArcticWolf
08-16-2005 12:11 AM
wcbcruzer
07-26-2005 11:34 PM
