Help Boost not working??
Old Jul 13, 2004 | 01:44 PM
infidel's Avatar
You have two options on your '95, middle port or hot line. They will read the same except the middle port isn't correct in reverse. I think the hot line is an easier install. You will need a 3/8''X1/8'' bushing for your probe and a 1k ohm resistor. The resistor is bridged across the leads that used to go to the stock sender to trick the PCM into thinking the temp is normal. If you have the bushing installed on your new probe and are ready to switch the stock sender for the new one rapidly you will lose very little fluid.
Sleigher
May 4, 2017 02:12 PM
Michigan Ram
Aug 24, 2011 11:25 PM
89dieselkong
Mar 17, 2011 01:18 PM
RoadDiesel
May 30, 2007 10:39 PM
NoSparkplugs
Sep 16, 2005 11:08 PM
