Help Boost not working??
Old Jul 11, 2004 | 03:07 PM
Towrig's Avatar
I am in the middle of getting my pyro (works fine pre turbo) and boost installed. The boost is not working. I pulled the instruction off of tst and pulled that plug where is says to put the boost at. It went in fine and I ran the line to the gague fine. When I fire up the truck I only get pyro readings. Did I so someting wrong. Its a 95 12v. Any help ASAP would be great!!
Old Jul 11, 2004 | 03:09 PM
Towrig's Avatar
This is where I mounted the boost at. I took out the fitting and put the new one in. Do I need to tap it?
Old Jul 11, 2004 | 03:34 PM
Shovelhead's Avatar
Administrator / Scooter Bum
You won't be able to see the boost guage move until you get on the road under load.
Reving it while sitting still won't generate enough boost.
BTDT
Ed
Old Jul 11, 2004 | 03:37 PM
BigBlue's Avatar
I can generate about 10 psi of boost reving in neutral. Get out on the road and you should see boost.
Old Jul 11, 2004 | 03:58 PM
Towrig's Avatar
Ok I did do all that when it was sitting. I reved it up for a few sec. Let me go drive it and see if it works. Thanks I will let you all know.
Old Jul 11, 2004 | 04:09 PM
Towrig's Avatar
It works. I guess I should have read the rest of the directions 20 psi is the most I got out of it. Is that about what I am looking for? I got up to 90 mph and my pyro got up to 1300. I need to drive it at 55 and see what it does. Thanks for the help.
Old Jul 11, 2004 | 04:37 PM
Boost sounds a little low, are you running a boost elbow on the turbo?
Old Jul 11, 2004 | 05:13 PM
Shovelhead's Avatar
I believe the stock (unmodified) wastegate will dump at around 19-20 psi.
Old Jul 12, 2004 | 12:07 AM
Towrig's Avatar
No elbow is that something I should do? My next step was to put a cam plate and 3k spring kit in, should I do something else first? I also now have another problem (I have not searched yet) but my ABS and brake light stays on now all the time it never happened before I did the gagues.
Old Jul 12, 2004 | 12:35 AM
edgrim's Avatar
Did you plug
..... your guage lights into your fuse box, maybe something as simple as a ground wire. Hope that helps.eg
Old Jul 12, 2004 | 01:05 AM
Towrig's Avatar
Yeah I am not sure, I was going to mess around with that after I get some sleep. I installed a Tranny temp gauge also and its not working. I figured the port I used must not get to much heat or something. I unpluged three before I found one it would work in. I may have drove those other ones back in to far?? Thanks for the input I will let you know what I come up with.
BTW this is one hell of a Web site, thanks for all the info everyone has!!
Old Jul 12, 2004 | 04:20 AM
infidel's Avatar
On your '95 RH tranny the middle port is the only one that will have correct temps.
Old Jul 12, 2004 | 06:20 PM
Towrig's Avatar
On the passagner side of the tranny? The one I am using is the upper left (if you under it looking at it from the passanger side). Am I in the right area?
Old Jul 12, 2004 | 06:46 PM
infidel's Avatar
Yep, pass side middle. Some people have had a hard time getting the probe threaded in right in this port. It is the right size and thread but doesn't have much taper. Running a 1/8'' NPT tap coated with grease down it will fix you right up.
Old Jul 13, 2004 | 09:36 AM
Towrig's Avatar
Thanks. I will check this out tonight. I posted on another thread about my gauge not working. It is stuck on 240 and will not go down. Could this be a bad ground. The other guy installed his on his hot line, is that a good idea or will this port you told me about work just fine??
