guages
guages
i just bought pillar guages and i was woundering where i can buy the boost fitting bolt and is there any other way to get trans temp hooked up other than drilling inti the pan thanks
and the trans; t-ing into the trans lines to the radiator is what some do and i think it's considered the most accurate reading... the pan i think is the most accurate after that and is easier to do. i'm not sure which trannies have em, but some have a test port or something you can use but word is that it's stagnant flow at that location and is basically like monitoring the case temp... not an accurate reading. what i did was bought an aftermarket pan $$ that had a fitting already in it. i was happy with it and would do it again.
good luck, j
yomitch
11-26-2002 09:16 AM
tobyw
11-13-2002 09:11 PM
phox_mulder
11-09-2002 08:17 PM
