GM wheel cylinder mod - PROBLEM?????
After doing all the research and homework on here, I decided to stop and pick up the 37337 this weekend to install since I was doing the pads and everything anyhow.
Problem- Napa specs show the 37337 as having line thread size of M10x1 where as the stock replacement called for 9026 which has line thread size of 3/8x24.
I did not find anything upon searching all the threads that any adapters or new fittings were required to fit the current lines to the new 37337. What have you all found?
Thanks I will be sure to triple check though just in case so I dont end up stripping something. Just my luck would be that I got the only 2 in the world with different threads. Full bore ahead now!!!!!!!!!!!!!!!
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
505diesel
Apr 3, 2005 11:54 PM
Journier
Nov 22, 2004 02:56 PM
