General HP limitations before studs/orings are needed
Old Nov 23, 2005 | 08:59 PM
Bobcat698's Avatar
What is the general limitation for HP levels with stock head bolts and gaskets for a 12V?
I plan on getting a HTB2 64/14 turbo. They wastegate them to 42PSI or so.
With proper fueling, etc; what kind of numbers can I put down before needing the studs and o-ringed heads?
Just asking for a general number. I realize the headgaskets can blow at lower than 50PSI boost levels.
Another way to put it may be: What HP can I reach before 50+ PSI of boost is needed to go any higher?
Old Nov 23, 2005 | 09:38 PM
northslope's Avatar
Various post I've read here and on other forums stock headgasket is good for 50 psi, but if you do a search on "ARP studs" look for DonM's post on'em you'll be pleasantly surprised check it out: https://www.dieseltruckresource.com/...ight=arp+studs
Old Nov 23, 2005 | 10:00 PM
Bobcat698's Avatar
I understand that, I'm asking what kind of HP can be made with an efficient *low drive pressure* 50 PSI of boost?
Thanks for the link.
Old Nov 23, 2005 | 10:12 PM
northslope's Avatar
ooooohhhhhhh I go away now
Old Nov 23, 2005 | 10:16 PM
Bobcat698's Avatar
I didn't mean to look like an ***hole in that last post.
Old Nov 23, 2005 | 10:23 PM
northslope's Avatar
As my wife says "you see it, hear it but ya just don't get it" no worries I should have read a little closer
Happy Thanksgiving!! to all
Old Nov 24, 2005 | 07:06 AM
More Power's Avatar
With stock headgasket and stock bolts retorqued to 118ft lbs i have ran 40,000 miles at 450 hp and 1024 ft lbs of torque made at 40psi with an htb2 62/12. I have blocked the wastegate many times for sled pulling to make more drive pressure to keep the charge lit in 4th low and blocked it will produce around 53 psi.
Old Nov 24, 2005 | 12:49 PM
Fueling around's Avatar
There is no magic limit or formula of how many mods before you blow.
Above stock levels you'll really find its not "if", but "when".
You've got 2 choices
1. Go until it blows
2. Do it now.
nmen
Oct 5, 2010 09:09 PM
lenuelmp23
Jun 14, 2010 11:11 AM
12valvetom
Oct 28, 2009 11:21 AM
12valve
28
Nov 5, 2008 03:57 PM
j28s
May 25, 2003 11:13 PM
