Fire rings VS. Orings
Old Oct 27, 2009 | 02:04 PM
12valvetom's Avatar
Which is better for daily driving? i heard fire rings don't do well with heat cycles? i also plow with my truck
Old Oct 27, 2009 | 11:00 PM
Mike D's Avatar
If the machine work is done properly both systems work fine, daily driver or not.
Old Oct 28, 2009 | 08:36 AM
XLR8R's Avatar
Your best bet for durability is stainless steel O-rings.
Old Oct 28, 2009 | 11:21 AM
1320's Avatar
In my research, most fire ring experts said, not for a daily ride. By around 20k miles they will need to be redone, or be leaking. For that reason I went with a stock head gasket with stainless wire oring in the head. I landed the oring wire in the center of the fire ring on the gasket. I cut the groove .030 deep and .039 wide. I used super glue to hold the wire well on the head, to be sure they didnt pop out during install. The wire protrudes about .010 . I copper sprayed the the oem gasket also, let it set up for about 30 minutes then installed it and the head.
ahire
13
Oct 17, 2008 12:50 PM
BigErksG2
Sep 25, 2008 06:43 PM
12VRoush
Oct 15, 2007 08:00 PM
1320
Mar 8, 2005 08:56 PM
