Gauges
Old Nov 30, 2005 | 02:09 PM
99NVRam2500's Avatar
Gauges
I am getting a gauge kit from rpmoutlet and was wondering if there was gonna be anything extra that I will need to get to install the tranny temp gauge. special line or anything.
Also, on a scale of 1-10 how important is the boost gauge? I want to put a fuel pressure gauge in its spot. in my opinion the fuel pressure gauge would be more useful. if the importance of the boost gauge is high, I will just get a column gauge pod also. I definately want EGT,Trans,Fuel pressure. that would be the a-pillar trio. and if the boost is of great importance, that would be the steering column gauge. thanks.
since I am gonna be in there. the clearance lights are going on too.. woo hoo.
Old Nov 30, 2005 | 04:40 PM
John Faughn's Avatar
Except for wanting a boost gauge , if your staying that close to stock then its a waste , boost gauges are for looking at unless your going to increase the boost [beyound stock] then you keep your foot out of it to keep from doing damage[ headgasget ] unless you get the big horse power bug and go to ringing the head , head studs, and on on .
The trans. will need to pick witch way you want to go [do some searching or posting to check out for that yr & mod.] you'll have to add some plumbing unless the guys suppling the gauge send that with.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
